climate control hiss
Old Apr 22, 2007 | 03:21 PM
califasbob's Avatar
califasbob
Hi,
I know there is a specific forum for this, but I've gotten my best info from the 73-79 usuals!
My '79 F-150 is an A/C truck, and everything in the climate control system works as it should. My system does hiss a little when I move the two levers and vacuum is distributed through the different lines, but only for a second or so...once the right flaps are open/closed it stops. Is this normal? A friend heard it and commented that I had a vacuum leak, but I'd always assumed I was just hearing the tubing empty out as vacuum was directed to it.
I worked for a man who had a '79 F-250 4x4 Camper Special in the early 80's. It was perfect, but I remember it also hissed.
I did dig into my dash this afternoon to have a quick look and none of the tubing looks too rough and it all seems to be secured.
Just wondered if your trucks do the same.
Thanks in advance,
Bob
Old Apr 22, 2007 | 05:04 PM
F250Moneypit's Avatar
F250Moneypit
Mine does that, I think it's normal. My dad had several Fords and Mercurys in the 70s and I remember all of them doing that from day one.
Old Apr 22, 2007 | 05:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation 1973 thru 1979 F150/350~all with a/c.
Originally Posted by califasbob
Hi,
My '79 F-150 is an A/C truck, and everything in the climate control system works as it should. My system does hiss a little when I move the two levers and vacuum is distributed through the different lines, but only for a second or so...once the right flaps are open/closed it stops. Is this normal? YES and NO..it depends on how long it hisses. Once the lever is moved, any hissing should stop.
Bob
Attached to the a/c-heater control panel (levers) in the dash, is the "Air Conditioner Vacuum Selector Control Valve" - translation = a multiported plastic vacuum manifold with a kicker switch. The plastic ports can break, the vacuum lines that attach to those ports swell over time and crack, the switch can short out. All these issues can and have been common problems with this part. Most Ford cars/trucks with a/c have used a similar type of A/C VSCV from the 1970's till today.
D5TZ-19B888-A .. A/C Vacuum Selector Control Valve (Motorcraft YH-285)
Old Apr 22, 2007 | 05:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sometimes a little silicone grease between the halves of the valve can stop some leaks.
Old Apr 22, 2007 | 06:10 PM
Mil1ion's Avatar
Mil1ion
Can you point out where you hear the hiss ?
http://www.clubfte.com/users/mil1ion...Hosehookup.jpg
http://www.clubfte.com/users/mil1ion/76_79w_AC.jpg
Old Apr 22, 2007 | 07:28 PM
califasbob's Avatar
califasbob
Great information, thanks. There are two areas where tubing goes in, three on the top of the unit, and five (I think) on the bottom. Each of these two connection points has an opaque rubber boot that serves as a coupler to the plastic ports on the "ACVSC". I think the the three going into the top boot are quiet, and that the bottom five are where I hear the hiss.
I'd guess that the longest it hisses is between 1-2 seconds. Idle changes slightly, but hardly at all (even when not engaging the AC compressor).
Bob
Old Apr 22, 2007 | 07:32 PM
califasbob's Avatar
califasbob
Sorry, Dennis...I didn't look before submitting. I'd say it's at the 8 point connector on the bottom (the second link you sent).
Thanks!
Bob
Old Apr 22, 2007 | 08:37 PM
Dustin1690's Avatar
Dustin1690
Mine 93 does it as well even with def mix and floor in winter time when its shut off i think its normal
Old Apr 22, 2007 | 08:46 PM
califasbob's Avatar
califasbob
15 years later and still doing the same thing, must be a reliable design. Thanks, Dustin!
Bob
Old Apr 23, 2007 | 08:05 PM
Mil1ion's Avatar
Mil1ion
Sounds normal to me.
The system has Vacuum switches.
What you are probably hearing is the vacuum switch re-diverting to a different port .
Put 8 straws in you mouth and try and suck on them..... one at a time
Kyo
Feb 7, 2013 06:29 PM
Nitesaber
Jul 7, 2011 01:55 PM
mmiller7461
Jan 27, 2007 08:14 PM
mtntop
Jun 14, 2003 01:29 PM
