2000 7.3 Stalling, Missing, No Power
Old Apr 22, 2007 | 09:53 AM
spiritdancer's Avatar
spiritdancer
This is my first post, and thanks in advance for your participation. I have a 2000 7.3, 4WD, auto, K&N cold air intake, and older style 75hp superchip. It started great and ran for about a mile and stalled. I let it get a little lower on fuel than I normally do (my brain fart). It acted like a CPS, so I replaced that and a new fuel filter(it was pretty grody). It started great, ran for about a mile and stalled again. Now it will start, but runs rough with no power. Any ideas??
Old Apr 22, 2007 | 10:00 AM
Uzumati's Avatar
Uzumati
Check the injector harnesses under the valve covers, Oil Level, IPR Tin nut (tight), ICP connector (no oil in connector)
Old Apr 22, 2007 | 10:04 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Welcome to FTE. How low was low on the fuel?
How much fuel in it now? Sounds like a fuel problem. Any other mods besides the older chip and have you changed anything lately?
Also, be sure to check the harnesses at the valve covers. Just give them a push pull check first and see if that helps. We can get deeper later if needed.
Old Apr 22, 2007 | 10:05 AM
FN74's Avatar
FN74
Is your SES light coming on? When it stalls does the engine start knocking loudly before it dies?
Old Apr 22, 2007 | 10:18 AM
spiritdancer
Thanks for all the replies. Oil level is OK, wiring checked. I let it get so low that my initial response was that I was out of fuel, it has the 2.5 gals I put in before I had it towed. Nothing has changed, no recent mods. I just started it and got a bit of blue/gray smoke and rough idle. There has been some loud knocking, intermittently.
Old Apr 22, 2007 | 10:25 AM
Tenn01PSD350
Get more fuel in it and try running it for a little while. Hopefully it will clear up.
Old Apr 22, 2007 | 10:27 AM
spiritdancer
You think I just picked up crud from the bottom of the tank? I will give it a try, thanks.
Old Apr 22, 2007 | 10:41 AM
Tenn01PSD350
Maybe, but 2-3 gallons across the bottom of the tank does not equate to a whole lot in terms of fuel level at the pickup. I would put in a lot more to make sure you eliminate a pickup foot problem.
Old Apr 22, 2007 | 10:47 AM
Uzumati's Avatar
Uzumati
I agree with Tenn, A couple of gallons in the bottom is not real deep when compared to the height of the pickup foot. Loud knocking can be air in the fuel it will make the injectors sound like hammers
Old Apr 22, 2007 | 12:07 PM
spiritdancer
That did the trick, first rule of mechanics...check the simple stuff first. I idled it for 10 minutes with 10 gal in it and then ran it to the station. Thanks for your help!!!
Old Apr 22, 2007 | 12:14 PM
Tenn01PSD350
Glad to help, and happier it was simple.
Jack Ewy
Aug 21, 2016 05:48 PM
highmilesguy
Dec 19, 2015 08:59 PM
Stang351c
Apr 10, 2013 08:38 PM
spinge
30
Nov 10, 2011 09:40 AM
adm7789
Dec 7, 2010 07:11 PM
