7.3 Starter
Old Apr 21, 2007 | 01:18 PM
pmbmax's Avatar
pmbmax
7.3 Starter
I have a start rpm problem. It does not spin over fast enough to crank up. The 2000 f 350 truck has 280000 miles on it new glow plugs ,under valve cover harness ,injectors, i checked it with scanner and somtimes it is only 300 rpm. ( their are 2 diff ones so the parts guys tell me )I have a new set of batts. and voltage is not droping to much. O and a compresion test when we did the glowpugs. and what type and how much trans fluid do i need to do a change. Thanks guys
Old Apr 21, 2007 | 02:15 PM
Kwikkordead's Avatar
Kwikkordead
That starter has done it's duty and then some.
Dextron ATF whether it's a stick or automatic.
Old Apr 21, 2007 | 02:25 PM
Cuda_jim's Avatar
Cuda_jim
Hey Kwik, You got your flame suit on??
Dextron? I'm not sayin' a word. SSHHH!
Old Apr 21, 2007 | 02:36 PM
Kwikkordead
Old Apr 21, 2007 | 03:03 PM
SpringerPop's Avatar
SpringerPop
Kwik,
Welllll, since there's no "T" in Dexron, maybe that's what he's ribbing you about. ;-)))
It's been around longer than Mercon, too...
Cuda,
It is what it is. Blind OEM brand-name allegiance isn't going to get you the best product for every application. But you've been around the world of wrench-twisting long enough to already know that. ;-))
I'll go with what's best, not whose name is on it.
Pop
Old Apr 21, 2007 | 04:38 PM
pmbmax's Avatar
pmbmax
is the gear reduction better or the huge one.? mitsub???? makes one and not sure on the other. I want the fastest so any input would be nice.
Old Apr 21, 2007 | 05:03 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
One of the guys on here just installed this one and he says it that it really gets the job done:
http://cgi.ebay.com/ebaymotors/New-F...QQcmdZViewItem
Old Apr 22, 2007 | 06:08 AM
Cuda_jim's Avatar
Cuda_jim
Naw, it wasn't the spelling. Dexron vs Mercon. Chevy vs Ford. Heck I make the same reference to ATF all the time, just thought I could poke a bit of fun at someone else. I sure didn't mean no harm
Old Apr 22, 2007 | 08:59 AM
SpringerPop
Cuda,
I could tell you were just funnin' him.
Just funnin' back a bit... ;-))))
Pop
Old Apr 22, 2007 | 09:08 AM
357fhp's Avatar
357fhp
About 2 months ago I put a 4 kv gear reduction starter on from DB Electrical
in Grey, Tn. 800-753-2242. It's the best addition I've done to any vehicle.
Old Apr 22, 2007 | 10:02 AM
Kwikkordead
I knew that it was all good natured fun. But I was so clueless until reminded of the other word on the label: Mercon.
It's a habit left over from my job. Dexron/Mercon are the same and I always order the case of Dexron ATF at work, never using the word Mercon.
Having a lot of grey hairs has it's downside.
EDIT: And nobody is too old to learn. Had to fix my typos.
I always thought it was spelled Dextron!
FN74's Avatar
FN74
Ah just get a rebuilt Mitsu type from your local Napa or Carquest and file away the receipt. There is really nothing wrong with the OEM style and I don't see any reason to spend extra money to upgrade it.
Old Apr 22, 2007 | 10:10 AM
357fhp's Avatar
357fhp
By the way including shipping the db starter was cheaper than autozone and lots cheaper than napa and no core charge.!!!!
Old Apr 22, 2007 | 03:42 PM
Cuda_jim's Avatar
Cuda_jim
Will dying your hair erase the downside? I hope so cuz I have a bunch too.
Don't feel bad even Amsoil and many other so called experts think it spelled with a "T" too.
OK I'm done hijacking this guys thread. Sorry.
