Dumb distributor question
Old Apr 21, 2007 | 09:10 PM
stewards68's Avatar
stewards68
OK, here's the dumb question of the day. I'm putting plug wires back on my 215-6. Which way does the distributor rotor turn, looking down from the top. clockwise or counterclockwise???
Old Apr 21, 2007 | 10:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Hit the starter
Old Apr 22, 2007 | 08:27 AM
stewards68's Avatar
stewards68
OK, I deserved that.... I thought of that, but don't have that much of the electrical system hooked up yet. That will be the fallback plan, though.
Old Apr 22, 2007 | 09:42 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Didn't mean to be flip,sometimes the most obvious thing isn't obvious when you're laying across the fenders! So, with your situation (no electrical) you can turn the engine by the crankshaft with a wrench in the same direction the fan turns (imagine it is a screw, biting into the air at the radiator and pulling it backwards) and see which way the dizzy rotor moves.
Another easier way is to look at the advance can. It pulls in to advance, so it is pulling against rotation. You could also say it points in the direction of rotation.
Old Apr 22, 2007 | 12:36 PM
59 shorty's Avatar
59 shorty
I am so bad with dizzies I could cross wire a 2 cyl. lol
Old Apr 22, 2007 | 01:10 PM
stewards68's Avatar
stewards68
I'm just teasing, too, I agree, sometimes the obvious isn't obvious. I'd thought about the advance thing, too, but had myself confused about whether it advanced with more vacuum or less... If it pulls to advance, that'll answer the question. The vac advance can sits at about 5 o'clock on the housing and points tangentially across the bottom to 7 or 8, so the silly thing has to turn clockwise...
Old Apr 22, 2007 | 06:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You got it!
You can also tell by looking at the points. The cam always comes from the pivot side of the points, towards the rubbing block.
IS your engine a flathead? I don't recall a 6-banger 215 that was OHV. I had a 53 and it was a 223 OHV.
Old Apr 22, 2007 | 08:16 PM
49fordpickumup's Avatar
49fordpickumup
Dist.
You said you were installing the wires, you have the firing order. The rotor has to follow the firing order. When in doubt find #1 and then the next number in the firing order would give the rotor direction of rotation. Have a great day,chuck
Old Apr 22, 2007 | 09:23 PM
stewards68's Avatar
stewards68
All the plug wires are gone, so the firing order trick is moot.
And yes, it's an OHV. It's kind of an interesting engine. It's almost identical to the 223. I'm told they only made it the second half of '52 and the first half of '53. The "experimental" Ford OHV, I've heard it called as well. They moved the distributor up toward the front and made a couple of very minor changes when they bumped up the bore to get 223ci. If you see one with the distributor smack dab in the middle of the block on the passenger side, it's a 215 instead of 223. The exhaust manifold also exits straight down instead of angled back. Basically all parts are interchangeable. Since nobody makes 215 pistons overbore, I ended up boring mine out for stock 223 pistons during the overhaul. I actually learned the most about the engine from a local Ford tractor expert. There was an aftermarket company that put the 215 into tractors, very few of them made which makes the tractors very sought-after by collectors. He has one of them and it made the "centerfold" of a tractor book.
Old Apr 22, 2007 | 09:30 PM
flareside_thunder's Avatar
flareside_thunder
unless ford and other manufacturers changed it should be Counterclockwise....
Old Apr 22, 2007 | 10:30 PM
stewards68's Avatar
stewards68
Oh good grief...just when I thought I had it figured out... I'm just gonna have to turn it over and see which way it goes...
Old Apr 22, 2007 | 10:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Look at the points, and the advance can. Sounded to me like you had it right.
Flathead V8's turn clockwise.
Old Apr 23, 2007 | 06:26 AM
stewards68's Avatar
stewards68
Thanks, man...
Iantiler
Jul 29, 2008 09:24 PM
WXboy
1983 - 2012 Ranger & B-Series
Dec 21, 2002 07:25 PM
Monsta
Nov 13, 2002 09:30 PM
otto
Jul 5, 2001 04:29 PM
