Maybe a dumb question..... will someone explain the advantage of setting timing gears straight up ( not retarded like late model), after market gears I been looking at have three settings 4 degrees advance, normal, 4 degrees retarded........ could this not be offset by distributor timing???
As I understand it the retarding was to help pass emissions testing. If you don't have strict emissions testing where you live you would probably do well to set it straight up. The timing chain is for the camshaft in relation to the crankshaft, you could only partially make up the difference by advancing the ignition(distributor) timing. Just the way I see it, hopefully you will get more replies.
Changing the distributor (spark) timing would have no effect on cam timing. Paul (Conaski) probably could tell you what would result from altering the cam timing.
Cam timing changes will alter the TQ and HP curves a cam produces, the amount is pretty small though. Advancing produces a bit more TQ, retarding produces a bit more HP. It's usefull to tweak a particular combo for a desired application, but it's far more effective to just use the cam that produces the desired powerband and install it straight up.
The +/- 4* is for cam timing events, not ignition.
88n94,EPNCSU2006,Conanski, quaddriver, thank for the replies, I have a mild cam installed ( Comp 260) I'll set the timing gear straight up and start playing with the timing.
