1978 - 1996 Big Bronco
No Spark
Old Oct 14, 2001 | 03:30 PM
83Bronco's Avatar
83Bronco
No Spark
I have a 1983 Bronco. One Day my wife used it and know I have no spark. I've tested the coil, ECM, and the disturber and everything checks out ok. But I don't get a spark out of the coil wire. whats going on I'm dumb founded. Has anyone else had this problem? The electrical wiring is on the old side being from 83 but seems fine. Thinking about replacing with Painless wiring. Has anyone used their wiring before? Any help would be apprecaited.
83Bronco
1983 Ford Bronco that thinks its a Chevy "Like A Rock"
Old Oct 18, 2001 | 01:20 PM
roguebronco36's Avatar
roguebronco36
No Spark
Iwould see if the wires from the distributor to the spark plugs are still in good condition and replace them if necessary. Also, check the plugs to make sure they have not gone out ar if they are corroded. I'd change both the wires and the plugs if it were my truck
Rob
Old Oct 19, 2001 | 10:53 AM
83Bronco's Avatar
83Bronco
No Spark
The wires and spark plugs are fine. I've tested at the coil for spark and nothing. It's got to be in the electrical wiring.
Old Oct 20, 2001 | 01:06 AM
Mil1ion's Avatar
Mil1ion
No Spark
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd1145c277e9ac3.gif
With the key on have you checked for power at the + side of the coil ?
Also, How did you check the Ignition Modulator ?
Dennis
Dennis
Old Oct 21, 2001 | 08:47 AM
SBV1's Avatar
SBV1
No Spark
Check to see if the distribuor rotor is turning. I had the same problem. It was a stripped timing gear. It wasn't turning the cam and subsequently the distributor.
Steve
Old Oct 21, 2001 | 01:42 PM
83Bronco's Avatar
83Bronco
No Spark
I had taken the ignition module and coil to Autozone and they tested them out and said they were fine. The rotor does rotate. All of the electrical wires are in good shape. I'm almost wondering if there is a computer somewhere in the truck that took a #####. Everyone that I've talked to doesn't know what it could be because of everything else tested out alright. I think maybe it's just time to turn it into my new race truck.
Old Oct 21, 2001 | 08:38 PM
Mil1ion's Avatar
Mil1ion
No Spark
[font size="1" color="#FF0000"]LAST EDITED ON 21-Oct-01 AT 09:45 PM (EST)[/font][p]https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd378791dbf8c3c.gif
You never answered my first question.
Do you have power to the positive side of the coil with the key on ?
Have you done a resistance test of the coil ?
You didn't say which Ignition system you have on that engine.
Duraspark?
Also, you might want to put a code reader on it.
KOEO - tests.
Dennis
Old Oct 22, 2001 | 05:58 PM
83Bronco's Avatar
83Bronco
No Spark
Mil1ion,
Thanks for telling me to go check and see if I had juice to the postive side of the coil. I put my test light on and evidently pushed the connection together. When I went to check for power it fired right up. I had to replace the original U shaped harness, because the positive wires had broken apart. Thanks for the info.
Old Oct 22, 2001 | 07:33 PM
georgedavila's Avatar
georgedavila
No Spark
Old Feb 14, 2003 | 08:05 AM
JWCCI's Avatar
JWCCI
No Spark
What would you look for if you had no power to the coil ?
1985 f-150 302 efi unsure of the ignition sys, althought the module is on the dist.? I also have no spark we changed the coil w/o any luck I also changed the module, checked all of the fusable links and the last thing is either a computer, or the computer relay. please advise.
Old Feb 15, 2003 | 12:17 PM
ryanguglich's Avatar
ryanguglich
No Spark
Just attach a voltmeter to the BATT side of the ign coil with the ign switch on and test for voltage.. it can be lower than battery voltage because it passes through a ballast. (if you disable your starter i.e. take the wire off) you can test start coil voltage (should be within 10% what the battery voltage is because it's a direct connection (no ballast) Just get a helper to hold the ign switch to start.
hope this helps.
country_squire
Mar 8, 2012 11:25 PM
dasanders123
30
May 14, 2009 09:33 AM
CK Off-Road
Nov 16, 2005 11:42 PM
oldgost
Bronco II
Apr 13, 2004 01:40 PM
Weberg
16
Apr 1, 2004 08:30 PM
