1978 - 1996 Big Bronco
no spark while cranking
Old Mar 8, 2012 | 04:21 PM
country_squire's Avatar
country_squire
I have a 1983 full size bronco with the 5.0 and i am not getting any spark while in start or run positions. the only time it does is when i let off the key and it sparks once. the coil tests good has a new ign module and i have respliced the wires to the distributor as per the wiring diagram at a loss from here any help would be appreciated
Old Mar 8, 2012 | 04:23 PM
country_squire
also there is power to the coil in both start and run. as well as a 6 month old distibutor
Old Mar 8, 2012 | 05:10 PM
greystreak92's Avatar
greystreak92
New ignition module? Did it ever turn over with this module in it?
Old Mar 8, 2012 | 05:37 PM
country_squire
no it actually died on me last night while driving and the old module tested bad new one tests good just replaced it about 6 hours ago
Old Mar 8, 2012 | 06:39 PM
greystreak92
Is the alternator internally regulated or is there an external regulator on it? If the regulator is bad, it could be that the alternator is killing the modules on you. Or you are just not getting enough voltage to the module.
Old Mar 8, 2012 | 11:25 PM
Torky2's Avatar
Torky2
That right there is the classic symptom of a DuraSpark II ignition system that can fire the ignition coil, but doesn't, because it is not getting pulses from the pickup inside the distributor.
Disconnect the plug into the distributor, and ohm out the two wires to the pickup. There may be three wires, one of them is a ground, you want the other two. Colors might be orange and purple. Should see something like 1000 to 2000 ohms or so if good. You are looking for an open (much higher resistance) or a short in winding of the pickup (way too low of resistance) if bad.
Spiritus
Apr 4, 2015 06:09 PM
Norton72
May 23, 2012 09:48 PM
76scout
Feb 24, 2008 06:23 AM
daerhldgs2
Sep 22, 2004 09:56 AM
mvassek
Electrical Systems/Wiring
Nov 14, 2003 06:54 PM
