Summit Racing "brand" headers
Old Jun 11, 2007 | 10:32 AM
Camperdaddy's Avatar
Camperdaddy
Gnater, What kind of gasket material did they come with and what bolts/studs did you end up using?
Old Jun 13, 2007 | 04:56 PM
gnater's Avatar
gnater
They came with bolts and paper gaskets that I didn't use. I bought Fel Pro steel gaskets (FEL-MS92568) and SVO locking header bolts (FMS-M-9432-A54) from Summit. The locking bolts are a PITA to put on, but much easier than going back to tighten loose ones.
Old Jun 24, 2007 | 07:46 PM
71dusterdan's Avatar
71dusterdan
i am thinking those headers are the cure for my problem. i swapped the manifolds when carbing my 89. i put on a set of manifolds from a buddy, but the y were not the same , mine had air tube holes everywhere. now i cant get the y pipe back on, the right manifold outlet is swept back farther. so i split the y pipe for duals and the right side hits the floor. hoping those headers will match the old manifolds outlet. they claim they are a bolt in. exhaust companies wont touch it cause of the removed cat. Dan
Old Aug 18, 2007 | 07:55 PM
71dusterdan
man fellas my headers were a breeze, they went right on. i did encounter that alignment problem, but just started all the bolts then cranked them down. mine came with nice fel pro gaskets, they were the summit brand, by pacesetter. they bolted right up to the y pipe, everything went fine, the truck is an 89 with a windsor. Dan
Redmanbob
25
Mar 26, 2015 11:33 AM
Scolesy8
Mar 6, 2009 04:11 AM
Twitchee2
20
Dec 2, 2007 08:24 AM
DJdemon6696
16
Aug 10, 2007 11:09 PM
RangerPilot
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 5, 2007 09:15 PM
