MC Leaks
Old Apr 20, 2007 | 05:32 PM
51dueller's Avatar
51dueller
Well the bolt is the same from the F-100 to the F-600. The block is different since the bigger trucks used 1/4" line instead of 3/16"
Bill, So you can't save pics from your cd manuals? Here's the pic:
Old Apr 20, 2007 | 06:44 PM
49fordpickumup's Avatar
49fordpickumup
Brake leaks
Another thought. Some copper and aluminum crush washers are made outside the USA. The metal is not good to use as a crush washer. Most crush washers are of a soft copper, etc. Should use only once then discarded. Also I've seen washers with a rubber center for sealing, must be rubber made for fluid used. Check at your local auto supply stores or ACE hardware. I think DOT 5 brake fluid doesn't harm anything rubber, check to be sure. Have a great day, chuck
Old Apr 20, 2007 | 07:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Nathan, Prolly can...but I haven't a klew on how to do that...and maybe that's not a good idea to teach me (wife says she will, hasn't yet)...FTE might run out of paper when I start posting pics.
1973/79 & 1980/89 books are on microfiche, only book on CD: 1964/72. Everything else is the printed word.
The upper pic on pg 33 shows a block similar to what someone asked about.
I'd prefer all the refs to be books..faster than fiche or CD's, but there's only so much room on this 6' dameter table.
Old Apr 20, 2007 | 08:56 PM
economan's Avatar
economan
i had the same prob when i put the f-350 one on my f100 cept' it wasn't a 3 way block that was leaking, but the one that pointed downwards with 1 line in it headin for the block located along the frame under the drivers floor. and the brk lite sw. instead of copper washers i used a fibrewasher, lasted for durn near 20 years.
mikie
near ottawa canada
58 merc 100 panel, 64 econo p/u
Old Apr 21, 2007 | 12:08 PM
dennisb56's Avatar
dennisb56
FINALLY!!!!! I drove the truck around the entire neighborhood today!!!! WOOHOO!!!
The leak was cured by using the new brass block and blot but taking everyones advice went to AutoZone and got two new washers with a metal ring and rubber center used for oil pan bolts. They were thicker than the copper and it went right together no leaks. My buddy came over and we bled the brakes and then got it running using a 1 gallon gas can drove it around a little, got a little braver and took it all through the neighborhood, even got it into 2nd gear for a while.
Thanks for all the support and tips and ideas. Back outside for some more fun!
Dennis
52F1
Old Apr 21, 2007 | 12:27 PM
ksmith203's Avatar
ksmith203
Great Dennis, I am going to try to take mine out today as well. I will let you know how it goes!
ronspolv
Sep 6, 2016 09:15 PM
abelmoreno
Mar 27, 2016 07:27 AM
Apocalypse
Nov 14, 2015 08:05 AM
60F100
May 2, 2009 09:22 AM
66ford400
May 19, 2005 01:40 AM
