How to tell the C-bushing degree?
Is there a way to tell the degree of the C-bushings that are on my truck without taking everything apart? I might very well be getting a set of radius arm drop brackets for christmas and I need to know whether or not to get a new set of 7 degree bushings (for a 6" lift spring).
Okay thanks. I have a feeling that it'll' be a bitch to get those 4 bolts off that hold the radius arms to the axle though. They look so rusted out that there isn't much of the "thread" left. Any tips on how to get them off? I figure I'll have to remove the springs and retaining plates, and the tires.
I just replaced my stock bushings. You have to pull the springs out and the spring plate have to be removed. The bolts on the spring plate go thru each have of the bracket. I had to remove my shock mounts also. I used a cordless impact on my radius ARM bolts they came out just fine. It takes a little effort getting them back in cause fighting the axle and holding the bracket can get difficult by yourself.
annaleigh
13
06-15-2016 09:29 PM
