Which Adjustable track bar or drop down bracket???
Old Mar 22, 2011 | 07:56 PM
BigTex68's Avatar
BigTex68
Red face Which Adjustable track bar or drop down bracket???
I have a 4in lift on my 68 f100 and i put the 4 degree c-bushings on and my track bar isn't long enough. Does anyone know which drop down bracket or adjustable track bars i should go with or can substitute for. Please help i am pay 6 bucks a day to keep it at the shop i was working on the truck at.
Old Mar 22, 2011 | 09:53 PM
PiNkPaNtHeR58's Avatar
PiNkPaNtHeR58
Deleted 4/3/2011.
Old Mar 22, 2011 | 11:47 PM
RichS2659's Avatar
RichS2659
Check out sites for suspension parts for 73-79 F-100/150's as they are exactly the same. Also check out the Big Bronco sites for the 73-79 BB's. The EB's aren't as wide. Try Bronco Graveyard.
Old Mar 23, 2011 | 06:17 PM
BigTex68's Avatar
BigTex68
ok cool thats exactly what i needed to know. i figured they would work but didnt know for sure. do you recommend doing the radius arm drop brackets?
Old Mar 24, 2011 | 03:26 PM
HIO Silver's Avatar
HIO Silver
I recommend using the RA drop downs (I used Rough Country).. ''did 'em on my rig with a Superlift Adj. track bar... I'm going with BDS on the track bar drop bracket. Theirs is beefy.
Old Mar 24, 2011 | 09:28 PM
BigTex68's Avatar
BigTex68
Your going to go with the drop down bracket as well as the adjustable track bar. So you got to do the drop Pittman arm to? what lift height are you going with.
Old Mar 28, 2011 | 10:57 PM
HIO Silver's Avatar
HIO Silver
I went with a 4-inch lift on my 73.. RA drop brackets, adj. track bar, and dropped Pitman arm. I passed on the track bar bracket because I didn't think I needed it. Now I've got bumpsteer because the track bar and the drag link are not parallel to each other and thus travel in different arcs. When I hit a BIG bump, the difference in the arcs results in the steering being yanked in either direction....
I suppose if I had gotten the track bar drop down bracket I wouldn't have ordered an adjustable track bar... However, it does allow the axle to be perfectly centered instead of the rig possibly dog-tracking down the road.
lackheezy
Oct 3, 2016 10:47 PM
bigblueexcursion
Jul 12, 2016 07:07 PM
ecampbell124
Mar 6, 2016 10:04 PM
Irish19614x4
Jan 9, 2016 06:08 AM
Gage2502
Feb 17, 2011 09:18 AM
