Hardwiring Electronic Overdrive?
Old Apr 22, 2007 | 07:08 AM
jroehl's Avatar
jroehl
Based on your RPM vs. speeds listed, you've got something slipping. If your torque converter is locked (which it should be at a constant speed on a level highway), speed vs. RPM should be proportional. In other words, if you're turning 2400 RPM at 60 MPH, then at 80 MPH, you should be turning 3200 RPM.
Either your torque converter isn't locking up, or your tranny is slipping badly. Or, like someone else said, your speedo may be off due to a rear gear or tire change.
Jason
Old Apr 22, 2007 | 06:04 PM
oobical's Avatar
oobical
31x10.5" tires and i have no clue on the gearing on the rear end just the stock 8.8
Old Apr 22, 2007 | 09:53 PM
jroehl's Avatar
jroehl
What's the code under "AXLE" on your door sticker? Those are not stock-size tires, so your speedo could be off. Any place you can check it? Some highways have markings at precisely 1/2 or 1 mile, so you could time it at 60 MPH (should take 30 seconds for 1/2 mile or 60 s for 1 mile).
Jason
tippmann87
2004 - 2008 F150
Mar 12, 2009 06:19 PM
oobical
Jun 26, 2007 09:32 AM
oobical
Apr 6, 2007 05:53 PM
oobical
Mar 11, 2007 02:55 PM
