3.55 vs 3.73
Old Apr 18, 2007 | 08:52 PM
  #31
Murk's Avatar
Murk
Originally Posted by tylus
the FX4 comes with 3.73 LS. it's part of the package
My '04 FX4 has the tow package and the 3.55's. =( I always thought it had the 3.73's, then I had to go and get curious and check on it!
Old Apr 18, 2007 | 09:48 PM
  #32
BigB's Avatar
BigB
gears with more grunt
I'll be picking up my 07 FX4 on Friday (I hope - long story). I thought I had spec'd the 3.7's but it turns out I hadn't, fair enough... dealer showed me my email. My new baby has the 20 inch wheel. This is a special truck for me, I have ordered it with a Roush SC (plus, plus) so I'm sure power won't be a problem. I'm thinking I may actually be better off with the taller gears - maybe one fewer shift on the way to the legal limit.
Anyone else have experience with the 3.55 vs the 3.7's when making a bunch of extra power?
Old Apr 18, 2007 | 10:07 PM
  #33
gui88ford's Avatar
gui88ford
you should be quite happy with that set up....
post some dyno runs and some pics of that bad boy and congrads....it's going to be an awesome truck...
Old Apr 18, 2007 | 11:32 PM
  #34
1979FordF-250's Avatar
1979FordF-250
Talking
I got the smallest truck with a 4.2 and a 5 speed. I was only able to upgrade to a 3.55 and that was as low as ford would offer for my truck. It was cool with the stock tires, and they would spin without using the clutch, and have a nice chirp into second. Since I got the 275/55R20's the ratio was horrible, especially for the 4.2 which doesn't have the best low end and is better on top. With the sticky toyos I could barely spin in first when its dry, but when its wet I do second gear burnouts all day.
I was considering a swap to a 3.73 but have been told it would be to small of a change for the effort. Then I considered 4.10 and that would be for pure fun and excitement. With the very common 8.8" though I found more uncommon ratios like the 3.90 and the 4.00, and now I just don't know.
I live in a rural area, so most driving anywhere is going to be 45-60 most of the way. When I go on the freeway on the occation its usually up the sierra nevada and it is a steep climb for a long way, so 65-70 is the fastest I will ever go occationally for extended periods of time. I also do alot of city driving like 45mph.
The truck is used for transporting my quad to the OHV parks and some have gotten prety hairy where first was almost not low enough, and its almost a granny low, at a 3.90 first gear
Any suggestions?
Old Apr 19, 2007 | 01:17 PM
  #35
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
mustang guys love the 3.90 ratio for automatics. with a stick you really don't need anything deeper than 3.73
3.90 and 4.10 are perfect for auto's because of the torque converter. with 4.10 in a stick, you really won't like 1st gear
Old Apr 19, 2007 | 06:59 PM
  #36
1979FordF-250
Question
thats true. Gear swaps in manuals usually make a bigger difference than autos. Im still a little unsure because of the 32" tires. Right now with 3.55 gears, I hate to say it but its guttless for my tastes, and the 4.2's have good potential.
Old Apr 19, 2007 | 07:37 PM
  #37
HomerWinzlow's Avatar
HomerWinzlow
My 01 with 4.2 had 17 inch aftermarket wheels and BFGs. It seemed to struggle even with 3.55. My current Scab with a 4.6 and 18 inch Lariat wheels and 3.55 seem a good match. Just right on accelleration. MPG seems as good as with the 4.2 so there must be less struggle getting to speed I would think.
Old Apr 19, 2007 | 09:04 PM
  #38
93RangerXL4x2's Avatar
93RangerXL4x2
can I or would I want to out a 3.73 in my 1998 4.2?
Old Apr 19, 2007 | 09:38 PM
  #39
1979FordF-250
The rim size doesn't really matter. Its the diameter of the tire. You can get 17" rim on a 20" tall tire or a 44" tall tire. I have 275/55/R20, which is 20" rims on a 31.9" tall tire. Far from stock.
Not trying to be rude or anything just explaining my reason for considering an even lower gear, like a 3.90.
Old Apr 20, 2007 | 07:57 AM
  #40
Turbodog1000's Avatar
Turbodog1000
Go for the Heavy Duty Payload package, 4.10's are standard. The ride is way softer than an F250 and my cargo cap. is within 90lbs of my friends F250 4X4 psd.
Macs1964F100
Jul 15, 2014 07:32 AM
srb1194
2004 - 2008 F150
May 8, 2010 09:42 AM
WOFP
Mar 25, 2006 06:49 PM
rocky35
Garage & Workshop
Mar 2, 2006 01:01 AM
alk3myst
1978 - 1996 Big Bronco
13
Sep 5, 2003 09:31 AM
