3.55 vs 3.73
Old Apr 18, 2007 | 01:40 PM
gui88ford's Avatar
gui88ford
Originally Posted by tylus
yep. or at least have 3 different gear sets in the lineup for all the body styles. I love my 3.73's. If it weren't so expensive to change out the front axle, I would consider swapping to 4.10's though. the initial "go" is just a little slow for me.
you would think goign to 20" wheels/ tires they would give you the option to have more gear....not less....
Old Apr 18, 2007 | 02:26 PM
rodneysch's Avatar
rodneysch
I have the 3.55 and never do any towing but have always wondered if that's
part of the reason I've averaged right at 17 mpg consistently in my 25000
miles I've put on my truck. I read mileage claims all over the place but these
numbers are always hand calculated, although my dash is indicating 17.2
right now. Last tank came out to 17.3. I live in San Diego so the mild temps
have to be a factor as well. But as for the gearing, I'm happy with the 3.55.
Old Apr 18, 2007 | 02:51 PM
gui88ford's Avatar
gui88ford
yeah, i think the 3.55s will help if you do a lot of flat driving.....
not to many flat spots in Pennsylvania...and i have the 3.73's...
i'm getting between 14.5 and 15.5
Old Apr 18, 2007 | 04:50 PM
irishammer's Avatar
irishammer
I have the 3.55's as well and they do just fine. Like everyone else says get the truck you like unless you tow quite often or tow heavy loads. If you put bigger tires on it changes your ratio as well so if you plan on bigger tires go for the 3.73's.
Old Apr 18, 2007 | 06:50 PM
fordtruckman's Avatar
fordtruckman
and how do you tell your gear ratio i looked at my door sticker but nothing really popped out at me showing me what i had, i'm gonna assume that since i have an STX i prolly have 3.55 but who knows, do you guys?
Old Apr 18, 2007 | 06:57 PM
DASTUD's Avatar
DASTUD
You would see it on your sticker as an upgrade option. If it is not there, it is safe to say you have the 3.55. Did you buy the truck new?
Old Apr 18, 2007 | 07:10 PM
DaMole's Avatar
DaMole
Look on your differential cover and you should see a metal tag somewhere there on one of the bolts that will have the ratio numbers. I think it will be
3.55 for 3.55 gear ratio
3L55 for 3.55 Limited slip
3.73 for 3.73 gear ratio
3L73 for 3.73 Limited slip
I think those are the numbers but I am not sure. It should be pretty close though.
Old Apr 18, 2007 | 07:23 PM
fordtruckman
hmm, ill look tomorrow but im pretty sure i got 3.55
Old Apr 18, 2007 | 08:29 PM
blams2004's Avatar
blams2004
Thanks for all the replies. I thought taht I had heard the FX4 came with the 3.73, also thougth I heard you could tell by the sticker on the door, something like if it had a B6 then it was the 3.73, can anyone confirm this. I know I read it somewhere on here but search turned up nada, thanks again all. My truck is an 06 FX4 5.4 Scab. I bought it as a demo model so I did not get a window sticker.
Old Apr 18, 2007 | 08:42 PM
gui88ford's Avatar
gui88ford
look on the rear it's self....their is an ID tag on there...the gear ratio is right on the tag....then yo know for sure...
Murk's Avatar
Murk
B6 is the 3.73's, H9 (like I have on mine) are the 3.55's.
Hey Tylus, how expensive is it to do the front axles anyways?
Old Apr 18, 2007 | 08:46 PM
gui88ford's Avatar
gui88ford
i've heard for the front's anywhere from 400 to 600 JUST FOR THE FRONT....now thats what i've heard only so it may or may not be correct...
when i had my mustang i have the gears swaped out in that to 4.10's an it only cost me 200 bucks....i supplied everything....only took him 40 minutes and he was done....i've always heard 1000 to 1200 for a truck to replace both...
Old Apr 18, 2007 | 08:49 PM
  #28
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
about double the cost of the rear end. there is more interference to be removed and it's a big PITA. I could probably get them installed front/rear for about $1,000 on top of parts $.
I'd rather put that money towards a supercharger though.
the FX4 comes with 3.73 LS. it's part of the package
  #29
irishammer's Avatar
irishammer
This is from an old thread... https://www.ford-trucks.com/article/...Decoder.html19 is 3.55
H9 is 3.55LS
B6 is 3.73LS
Old Apr 18, 2007 | 08:51 PM
  #30
Murk's Avatar
Murk
Sweet, cuz I am working on getting cash together for a lift and new rims and tires and naturally, probably a swap to the 4.10's and I'll need to front and back.
