Rainwater inside doors
Old Apr 19, 2007 | 08:45 PM
Europhil's Avatar
Europhil
Newbie here - would appreciate some advice. I've got a '05 Supercab parked on a sloping driveway, usually with the bed-end on the downhill side. I have noticed a good bit of water pouring out of the rear suicide doors when I open them up. Am I going to have a rust issue here, or is this normal? Should I worry about which direction the truck is parked?
Thanks
Old Apr 19, 2007 | 08:59 PM
T-B_MN's Avatar
T-B_MN
Where is the water pouring out of? The inside of the door or the inside of the truck?
Old Apr 19, 2007 | 10:33 PM
Europhil's Avatar
Europhil
Ha! It's inside the door and exits through the normal drain in the bottom of the door. I just don't quite understand why it wouldn't be designed to drain properly when parked on a slope and I don't know whether this spells eventual doom for the doors or not. Any tips appreciated.
Old Apr 20, 2007 | 09:58 AM
sysman_rick's Avatar
sysman_rick
Clean out the drain holes with a wire smaller than coathanger wire. Do NOT try high pressure compressed air !
