'93 Aero*,4.0L,auto,AWD. Whenever the A/C compressor kicks in, the idle speed actually increases. When the compressor kicks out the idle drops. Is there an adjustment somewhere to equalize out the A/C on and A/c off idle speeds?
Ok. I thought there might be a solenoid or "kicker" to just increase the idle speed enough to compensate for the compressor coming on, not making the engine actually idle at a higher speed. When the A/C kicks in at a light, it physically jerks the van forward.
The Electronic Engine Control (EEC) System uses a Powertrain Control Module (PCM) to control fuel flow, exhaust gas recirculation (EGR), ignition system functions, evaporative emission, idle speed, engine cooling, and transmission controls.
The A/C Signal is received from the A/C system at pin 10, which informs the PCM when the A/C clutch has been turned on. Under certain conditions, such as heavy engine load, the PCM will ground pin 54 to energize the WOT Cutout Relay. This deenergizes the A/C Clutch Field Coil and disengages the A/C Compressor, reducing engine load.
96...thanks for the explanation, but, this is happening at idle,not WOT. in my case,does the PCM tell the IAC module to let more air through to increase the idle speed when the compressor goes on?
