5.0 HO help? pics
Old Apr 24, 2007 | 08:07 PM
lnlycrpr's Avatar
lnlycrpr
i apologize for the confusion. yes the dashpot that i'm referring to is the EGR and we have that hooked up to a vaccum source on the intake manifold. i do not know the location of the EVR though, and not even sure if its still in the engine bay.
would the EGR cause the motor to flood itself? we've been having issues with starting the truck. with the fuel relay connected the motor will flood itself during startup. if we disconnect the fuel relay, then it will startup, but the moment we reconnect it, the motor instantly shuts off. we've replaced the fuel pump, filter, and FPR, but cant seem to come up with an answer. we're stumped on this one. i cant thank you guys enough for the help you given us.
Old Apr 24, 2007 | 08:28 PM
taisa899's Avatar
taisa899
I'm thinking injectors stuck in the open position
Jim
Old Apr 25, 2007 | 06:32 PM
EPNCSU2006's Avatar
EPNCSU2006
If the EGR valve is actually opening (not stuck), connecting it to straight manifold vacuum will cause it to run pretty ragged.
skid pan
May 15, 2010 08:02 PM
blindboyth
17
Oct 23, 2008 09:00 AM
Sandman1991
21
May 26, 2007 12:49 AM
chrono4
Engine Swaps
May 15, 2004 11:30 PM
jams3
Dec 4, 2000 11:53 AM
