Can anyone tell / show me what the lock tab looks like in step 4 below? I've been looking at the manual and the illustration leaves a lot to be desired since looking at the actual piece under the truck I don't see anything that looks like it could be pried down with out breaking the locking piece nor would anything move solely by hand pressure. for 93 F-250 5.8 E4OD.
Below posted by PLC7.3 (I have identical in shop manual)
Automatic Transmission Shift Rod or Shift Cable Adjustment... C6 and E4OD
1 Raise vehicle on jack stands or hoist. (I'd block well and scramble under)
2 From inside the vehicle, place the select lever in D/C6 and OD/E4OD . Hang a three pound weight on the selector lever ( six pack still full)
3 Remove shift cable from the transmission lever ball stud/shift rod.
4 Pull down the lock tab on the shift cable body.
5 Position transmission lever in drive position. This is three detents from the front-most lever position with the first position counting as one.
6 Connect the cable and end fitting to the transmission lever ball stud/shift rod.
7 Push up on the lock tab to lock the cable in the correctly adjusted position or tighten nut
and bolt.
8 Remove jack stands and lower vehicle from hoist. Remove three pound weight from column shift select lever.
9 After making adjustment, check for Park engagment. Check the transmission control lever in all detent positions with the engine running to make sure correct detent/transmission actions, readjust if necessary. Reset the PRNDL indicator as required.
CAUTION:
Under no circumstances will it be permissible to adjust the cable/shift rod in any position
other than D for C6 or OD for E4OD.
Now all should be ok if it is in PARK and everything works, remove blocks.
It has been a while since I was under there, lock is down near the transmission and as best as I recall the lock tab is on the cabin side of the support bracket. If you have trouble getting the lock tab to move, it is shaped roughly like a 'U', put something flat on top and pull down on it. You would then be pushing down on the top two legs of the 'U'. I used a slot screw driver and it popped right down. I had been prying on the bottom of the U lock tab and it was bending so far I was sure it would break if I went any further.
