Sloppy shifter lever
Old May 23, 2015 | 12:48 AM
Rob_82's Avatar
Rob_82
Hey guys so I've been experiencing the ever so popular sloppy shifter lever in my 02 excursion. So naturally I started prowling around the site looking for answers to my issues. I have ensured both of the torx bolts are present and tight at the end of the shift tube on the bracket that connects to the shifter cable and have replaced the shift tube (It was worn out) and it helped a great deal but has not completely fixed the issue so today I crawled underneath the truck to try and adjust the shift cable and have found that the detent in the shift linkage from the gear position sensor that runs to the shift mechanism (not sure what it's called) that is inside the transmission is really nonexistent, it is effortless to move it from P to R but from R to N is good and stiff like it should be but from N to D and D to 2 is effortless. I have zero experience with what creates the detent inside of the transmission and was wondering if anyone has a link or pictures or write up something that I can look over and attempt to educate myself on before I dive in to this blind any help would be greatly appreciated
Old May 23, 2015 | 10:29 AM
Apocalypse's Avatar
Apocalypse
Wow, I do have to say congratulations on doing as much as you did before posting and then in your post being extremely descriptive! This helps a lot and I really hope someone can chime in with some helpful tips on this. While you wait you can add your location to your profile and maybe a pin to the Excursion owners map and see who is close to you to lend a hand with the repairs
Old May 23, 2015 | 10:46 AM
agsmv1's Avatar
agsmv1
I had a similar problem on my dodge durango. I thought it was the cable but turned out it was the detent pin inside the tranny. Had the shop replace it for me as the pan has to be dropped and who knows what else. I also had the problem on my EX, but tightening the tor bolts fixed the problems for me.
-Art
Old May 23, 2015 | 10:51 AM
LivingLarge's Avatar
LivingLarge
Originally Posted by agsmv1
I had a similar problem on my durango. I thought it was the cable but turned out it was a DODGE.
-Art
Fixed that right up for you
Old May 23, 2015 | 11:50 AM
agsmv1's Avatar
agsmv1
Haha...considering that is the only work that has been done to it except for regular maintenance, I will take it.
Old May 25, 2015 | 11:16 PM
Rob_82's Avatar
Rob_82
No one has any information on the detent mechanism (I'm sorry I don't know what this part is called) inside the transmission? I appreciate the few responses I've had however they havnt really shed any light on my issue somebody out there has messed with this before I just really have no clue what I'm up against I went to the ford dealer today and got an exploded view of what the parts look like but it is just a picture anyone have any input on what exactly I should be looking for when I take this apart?
Old May 25, 2015 | 11:36 PM
Apocalypse's Avatar
Apocalypse
Don't think so. You might have more luck in the motor specific forum though. It's kind of an odd question
Old May 26, 2015 | 07:18 AM
projectSHO89's Avatar
projectSHO89
Try the TRANSMISSION-specific forum, this has nothing to do with whatever engine is attached. It's a mechanical issue INSIDE the tranny.
Old May 26, 2015 | 06:01 PM
Stewart_H's Avatar
Stewart_H
We are not so rigid that questions about transmissions and other related subjects can't be asked in this forum.
The Ex forum and the 7.3L PSD forum are especially flexible when it comes to 4R100 transmission questions.
Stewart
Old May 26, 2015 | 06:05 PM
Stewart_H's Avatar
Stewart_H
I PM'd Mark K to see if he had anything to add for you.
Stewart
Old May 26, 2015 | 06:39 PM
Rob_82's Avatar
Rob_82
Ya know I never even thought about the transmission specific forum.... I will def post up there thanks for the tip... I will also post findings here for anyone that was curious!
Old May 26, 2015 | 07:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I know exactly what you mean. We call it the rooster comb. Here's a photo: E4OD problems - Diesel Forum - TheDieselStop.com. The photo is of an E4OD, but the 4R100 is identical here.
The part at the bottom of the photo that is bolted to the case is the spring. I'll bet it's broken. A new one is probably really inexpensive, and it isn't hard to install once the pan is off.
Old May 26, 2015 | 07:30 PM
Rob_82's Avatar
Rob_82
Stewart thanks for that pm!
Mark that is exactly what I was looking for now I know what to look for! Thanks so much
I will be dropping pan tomorrow I will post my findings thanks again guys!!
Old May 26, 2015 | 08:03 PM
projectSHO89
Stewart
The suggestion was based on where the individuals most likely to know the answer would be most likely to find the post.
Old May 26, 2015 | 09:17 PM
Stewart_H's Avatar
Stewart_H
The composition of your post, and the was you emphasized certain aspects of it made me feel like it was less of a suggestion and more akin to a rigid rule to be followed. But hey, I post like that sometimes without meaning to so I completely understand.
Stewart
