Low boost after Wicked Wheel install
Old Apr 16, 2007 | 04:47 PM
greenhighboy's Avatar
greenhighboy
I had the turbo off over the weekend and installed a Wicked Wheel and now can only get 15 lbs. of boost, with the stock wheel I could get 22 lbs. I can't hear the Kwick filter sucking air anymore either. I have checked the intercooler boots and the intake connections and they are tight. The truck runs fine just not as much boost as it should have. TIA for any help.
Old Apr 16, 2007 | 04:56 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
id say check you waistgate actuator, you probably moved it, or its loose, that will blow off sooner, and you wont make as much boost,
just somthing to check, and those boots will make big problem if they are leaking, check all of it again
and can you spin the wheel by hand and is it free, no rubing of any kind?
Old Apr 16, 2007 | 05:00 PM
wlihntr's Avatar
wlihntr
the WW will make less boost than the stock wheel but normally not that big a drop. usually its 2-3 psi less
Old Apr 16, 2007 | 07:24 PM
Kwikkordead's Avatar
Kwikkordead
Something is wrong somewhere and it's not the WW. Keep looking for something loose.
Do you have a lot of black smoke when you floor it?
Old Apr 16, 2007 | 11:36 PM
CSIPSD's Avatar
CSIPSD
Did the oring on the compressor housing come out?
Old Apr 17, 2007 | 12:28 AM
1996pwrstrk's Avatar
1996pwrstrk
Cookie and I did the WW on mine last weekend and my boost is higher now, more than once on the HP setting I have hit 35lbs but we also removed the ebv , and did the ITP tank kit mod with a extra fuel pump thrown in for good measure. That might be the difference .
Old Apr 17, 2007 | 01:10 AM
Mach1's Avatar
Mach1
Check the up-pipes for an exhaust leak, if you aint got the heat driving the turbo, you wont have the boost...
Old Apr 17, 2007 | 08:57 AM
greagin's Avatar
greagin
This may be a huge matter of opinion, but i am doing the WW install next weekend and i am considering taking off the ebpv. pros and cons?
Old Apr 17, 2007 | 11:43 AM
greenhighboy
Thanks for all the recommendations and I'll check everything again tonight. I didn't have time to look at it last night.
Old Apr 17, 2007 | 12:44 PM
Black Smoke 02's Avatar
Black Smoke 02
You shouldn't lose boost with a new wheel such as the WW or banks high compression wheel. I would say there is a leak somewhere.
Old Apr 17, 2007 | 01:24 PM
CSIPSD's Avatar
CSIPSD
Yes you will loose a little at WOT... 1-2psi MAX. Anymore then that and something is going on.
Old Apr 18, 2007 | 09:21 PM
greenhighboy
Update !!
Guys I checked everything last night,tightened the crap out of every clamp looked for exhaust leaks and it didn't improve any at all.
I came home from work tonight and pulled the turbo back off just to look at everything and do a reinstall. It's amazing how easy and fast it is the second time in a week. I didn't find any leaks or see anything wrong and put it back together. I had my wife test drive it while I picked tools up and she pulled back in smileing. She tells me it made 21lbs. There was a leak of some kind somewhere but I don't know where.
So I wash my hands and go for a test drive, it runs totally different. It doesn't make the wierd sounds when it shifts now and the boost stays at a steady 21lbs. after shifting.where before it would drop off. I have a gooseneck trailer loaded with green firewood I'll hookup tomorrow night and see how it does with a load behind it.
Thanks to all who replied with ideas
Old Apr 18, 2007 | 09:43 PM
greagin's Avatar
greagin
my brother in law is having the same problems now. he is currently looking for leaks everywhere
Old Apr 18, 2007 | 09:51 PM
Black Smoke 02
Glad to hear the problem is fixed.... Quick question off topic for CSIPSD??? I was just curious on how you like your injectors and water/methanol injection. Also curious if you did any modifications internally??
Thanks Jeff
Anthony Giovino
Ford Truck Parts for Sale
Apr 15, 2017 07:50 AM
Leatherneck007
18
May 13, 2016 08:15 PM
mrwrench
Sep 3, 2015 02:21 PM
wannabe7.3
Dec 28, 2014 03:18 PM
yme450
Oct 19, 2010 06:45 PM
