voltage dropping
voltage dropping
I have a 1998 e250 with a 5.4 180,000 miles on it. The alternator crapped out the other day so i replace it and no when i pull my 16' enclosed trailer The voltage drops big time and will kill the batteries and there i sit stranded i even went as far as trying a another new alternator and new battery and still does the same thing is there somthing else i should try? Thanks
Unless you went with a really crappie barnd of alternator I would suspect a problem with the trailer wiring. You should have at least the 135 amp alternator on there you need to check and see that you have at lleast as big an alternator as the orginal. The rule is you can go bigger (amperage wise) but never smaller.
It almost sounds like you have a bad ground at the trailer. If you haven't done so already you may want to add a(n extra) ground wire to the harness for the trailer (should already be there). The hitch ball to trailer connection is not a good enough ground. You may also want to make sure that there isn't a short somewhere in the wiring on the trailer. Does the trailer have a heater/ac unit? Is it maybe stuck on?
Reguardless of price, parts store chains like Auto Zone and Advance have poorly built electrical devices, lifetime warranty, means you spend your life replacing it. I had my stock alternator rebuilt by a reputable shop, they even beefed it up to the max the case will allow, produces far more amps than it did before.
areoseek
43
11-22-2013 12:03 AM
schickgrp
1997-2006 Expedition & Navigator
02-03-2006 11:42 AM
