Sponsored by: Innova
sub question
Old Apr 14, 2007 | 09:16 PM
dantheman88125's Avatar
dantheman88125
sub question
i have a 02 ford ranger edge with a 6 cd changer and i was wondering if i would be able to hook up a sub and amp to it or do i need to buy a whole new deck?
Old Apr 14, 2007 | 09:45 PM
powerstroke6ltr's Avatar
powerstroke6ltr
You could do a factory integration like a rockford 360 or kenwood one, and then to an amp. It allows you to keep your existing hardware but have a cleaner signal and a system that performs like a high end stereo system...
Old Apr 15, 2007 | 11:27 AM
dantheman88125
can i use any sub i wanted??
Old Apr 15, 2007 | 10:41 PM
powerstroke6ltr
yeah you can... 1. The factory integration allows you to amp and run a subwoofer, any kind and it will also make the speakers have higher clarity. All the factory integration does its process your signal coming off the factory deck and allows for different equalizer settings and the addition of a few other gadgets. 2. You could also run an amp with line level outputs to a sub and not have to worry about the factory integration. 3. Another option you have is to run a self powered sub and not have to worry about selecting the right amplifier for the sub you want to run. A powered subwoofer won't win any contests but it will provide MUCH more bass than speakers ever could.
I am running a Kenwood KSC-WD250 right now in my diesel and with the windows down I can still hear the bass plenty going highway speeds... I have no complaints. Stay away from the KSC-SW1. It has to work way to hard in order to supply any bass and is easily overworked.
If you want to amp your speakers too, I would spend the extra $$ on an Infinity Bass link II with a 4SC amplifier add on. It is self contained and allows you to amp 4 speakers as well as add the subwoofer.... bit spendy though.
Hope I helped!
lemasters f100
19
Feb 19, 2014 08:44 PM
DELBERT
Nov 10, 2005 10:02 AM
2004lariat
2004 - 2008 F150
Oct 19, 2004 09:20 PM
cozmo
Nov 4, 2002 12:36 PM
