1978 - 1996 Big Bronco
Ignition missing out, stalling, when humid
Old Dec 11, 2001 | 10:02 AM
WHOHOO's Avatar
WHOHOO
[updated:LAST EDITED ON 11-Dec-01 AT 11:38 AM (EST)]Hi all again!
I just signed up and already the second question...LOL!
Ok, here it goes...since about 4 month my 89 Bronco (302EFI) developed the following problems when it is humid outside or when it rains...same thing if engine is cold or hot...absolutely no problems in dry weather conditions:
1. At idle, RPM drops down, sounds like one or more cylinders dont get a spark, sometimes stalls completely
2. Driving at constant speed, engine looses power for fractions of seconds, rarely stalling tho.
3. Braking to a stop, engine stalls often.
4. Accelerating out of low RPM engine makes sometimes almost pinging noise (timing checked - OK) and tach needle "jumps" according to the noise.
What i did so far: Replaced spark plugs, rotor, cap, wires and the ignition modules failed about a year ago and was replaced then.
Someone can think of more? Would be nice to get that fixed before the big winter mess outside starts...LOL!
Thank you so much,
Marcus.
Old Dec 11, 2001 | 10:51 AM
adelyser's Avatar
adelyser
Have you pulled the trouble codes from the PCM yet? They may lead you directly to the problem. On the other hand, the PCM may indicate that everything is okay. It is a quick and simple check, and cheap too.
Aaron D.
Old Dec 11, 2001 | 04:42 PM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 11-Dec-01 AT 05:54 PM (EST)]I think your problem is related to Fuel.
I suggest getting a code reader,besides screwing things up,that's what the computer is for.
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 11, 2001 | 07:33 PM
JBronco's Avatar
JBronco
This may be grasping at straws, but it might help you. I was listening to those Car Talk guys the other day. A lady called in with a Honda that would not start when it was humid. It turns out there there is an ignition control module under the dash that is notorious for doing this on older Hondas. The cure was a few bucks and a module that simply plugs in. Anyway, I don't know if this is the case with a Bronco. But it may give you some ideas.
Old Dec 11, 2001 | 11:14 PM
restorit's Avatar
restorit
Your tach jumping along with the humidity bringing out the problem is indicative of something in the ignition. I know you said you changed out the ignition wires a while back, but did you use a quality set? Your symptoms sound exactly like a bad set. Try this on a warm, dry night..... take a squirt bottle and, in the dark, mist water over the wires. If they're bad, you'll see them arcing. (Humidity will make the problem worse). Good luck!
Old Dec 12, 2001 | 10:48 AM
adelyser's Avatar
adelyser
I would also check that ignition module again. I had an '88 F-150 with the 302 EFI, and when I went to replace the module, I had them check the new module at the auto parts store, and 2 out of 3 were bad right out of the new box.
Aaron D.
Old Dec 14, 2001 | 02:29 PM
WHOHOO's Avatar
WHOHOO
Post Ignition missing out, stalling, when humid
Ok, short update from my side...and thank you so much all for your replies!!!
Because we have wet weather up here in the NE since a couple days, I had the chance to try different things. One thing I did was trying to spray certain things with WD-40 to try to get the moisture out. Today, after a quite "bumpy" ride again in the morning and rain and fog the night before, I took off the lil cap of the distributor-cap and sprayed some WD-40 in there...and...the car ran fine for the afternoon! So, now I guess even that it is a new cap, there is somehow moisture getting in there. Anyone had any experiences like this before? Try another new cap? Try to somehow seal the cap with something?
Thanks for all your help so far,
Marcus...;-)
Old Dec 14, 2001 | 05:34 PM
Mil1ion's Avatar
Mil1ion
How much Temperature fluctuation do you have where you live?
This can cause humidity in the cap to not go away.
Dennis
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
Old Dec 14, 2001 | 05:37 PM
Mil1ion's Avatar
Mil1ion
mashenden
62
Jul 29, 2022 12:29 PM
yasky69
2004 - 2008 F150
Aug 2, 2016 10:19 PM
FordGirl2009
2009 - 2014 F150
Jul 28, 2015 04:07 PM
micromack
May 25, 2015 09:30 PM
ImConfused666
33
Jul 2, 2014 03:23 PM
