4.6 engine knock!!!
Old Apr 14, 2007 | 06:00 PM
soxfan81's Avatar
soxfan81
Question 4.6 engine knock!!!
Today I did a oil change on my 05 screw 4.6 v8 w/ 24000 miles.I have done all my own oil changes since I bought it new, will this affect a warranty repair. The engine sounds like a diesel at idle not right away. I have to let it warm up for a minute or two and then the noise starts. I can not hear the noise from the inside this maybe why I haven't heard it before. My oil is motorcraft with a motorcraft filter. If I raise the idle to 800 - 1000 the noise goes away (I had someone press the pedal while I listened) I have read other post all talking about the 5.4 not 4.6. I appreciate the help guys thanks!!
Old Apr 14, 2007 | 09:11 PM
pukemon's Avatar
pukemon
bad gas maybe?
Old Apr 14, 2007 | 09:39 PM
soxfan81's Avatar
soxfan81
I just filled up at a BP that I always use. I also changed the fuel filter today to don't know if that has anything to do with it. maybe air in the line.
Old Apr 14, 2007 | 10:02 PM
fordtruckman's Avatar
fordtruckman
Maybe you overfilled it, although i doubt it. I'd take it to the dealership, and actually talk to a technician and walk with him out to the truck and show them, thats about the only way that the dealership will no whats wrong. Good luck.
Old Apr 14, 2007 | 10:07 PM
fordtruckman
read this, TSB
Old Apr 14, 2007 | 10:09 PM
soxfan81's Avatar
soxfan81
Thanks I have already emailed the dealership I have bought it from and I put 6 quarts in it and checked the dipstick all looks good but sounds like a diesel.
Old Apr 14, 2007 | 10:15 PM
soxfan81's Avatar
soxfan81
I have the 16 valve V8. I think the 3 valve 4.6 is in the mustang.
Old Apr 15, 2007 | 01:37 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yep, the 3v 4.6 is in the Mustang GT
the trucks get a 2v 4.6
sounds like you don't have enough oil in the motor, or you put too much into it.
Old Apr 15, 2007 | 07:33 AM
soxfan81's Avatar
soxfan81
6 qts like the book says, and I always check the dipstick to make sure
Old Apr 19, 2007 | 05:20 PM
soxfan81's Avatar
soxfan81
I went to the dealer today and they told me that my engine does not have a knock. That it is normal and if the noise doesn't get worse with higher rpm's there is no problem. My neighbor has a 97 4.6 and his doesn't have a knock. I can not hear it inside my truck but outside I hear it. The dealer also said since I have done all my own oil changes any engine claim would be denied from ford motor corp. Does this sound like a bunch of BS? Should I go to another dealer? Looking for some advice guys thanks in advance.
Old Apr 20, 2007 | 02:08 AM
yardbird's Avatar
yardbird
Is the knock louder on one side than the other. Try listening through the wheel well and see.
My 4.6 has a knock at idle that begins about 2 minutes after startup. It will go away at 1000 RPM and above. My knock is on the left (drivers) side.
Dealer hear it, says it's not right, but I am out of warranty. I will drive it until it breaks, or I find a dealer who will take it like this.
Old Apr 20, 2007 | 03:10 PM
soxfan81's Avatar
soxfan81
The drivers side sounds worse but not by alot.
jwdenney2
2004 - 2008 F150
Dec 23, 2015 01:15 AM
bikeski1
1997 - 2003 F150
May 7, 2013 11:38 AM
pantherscat
1997 - 2003 F150
Nov 10, 2010 11:57 PM
Peties3
Modular V8 (4.6L, 5.4L)
Oct 7, 2005 06:07 AM
Folly5678
Dec 2, 2003 12:10 AM
