93 4.9 wont start
Old Apr 13, 2007 | 07:37 PM
static585's Avatar
static585
Cool 93 4.9 wont start
ok so i got a 93 f150 4.9. i got this truck and it sat for 5 years. but fired up. so i did a tune up, sparks,wire,cap,rotor,pvc,air. it also started with no problem. but one day it started rought but after awhile it would go but die then start. it did for a while but ran. well i notice that the fuel filter was leaking some try to make it work by using rubber hoses cause they didnt have the tool. then the next day the truck wounld start for anything. so i replace the fuel filter with a new one and the right way. well still wound start. the pumps kick in. the psi at the rail is 40 and does really drop when cranking when key on. the sparks sprak. so i am lost please help me. thanks
Old Apr 14, 2007 | 02:18 PM
ubereal2's Avatar
ubereal2
Is the fuel in the truck any good? After setting for five years, I'd have to drain the tank and get some fresh fuel...
Old Apr 14, 2007 | 06:42 PM
static585's Avatar
static585
yea it fresh fuel i ran all the old gas out when i got it. and put some cleaner thur the lines as well
White Mountain Goat
Oct 1, 2014 08:58 AM
dontmakbad
15
Jan 17, 2012 06:08 PM
udder
May 3, 2011 07:02 AM
kevin_724
Dec 3, 2003 09:41 AM
GammaDriver
Aug 25, 2002 12:12 AM
