300ci torque?
Old Mar 29, 2007 | 11:09 AM
neomac3444's Avatar
neomac3444
300ci torque?
does anyone know how much torque a stock i6-300 puts out? perferably a 90's model?
Old Mar 30, 2007 | 08:33 AM
BigBlue88's Avatar
BigBlue88
About 260ft-lbs peak, and well above 200ft-lbs from just off idle to around three grand or so. About 150HP in stock trim. With a cam and some mild work, torque goes well above 300, HP above 200 and the RPM range extends out a lot further (stock cam signs off at 3500).
Old Apr 13, 2007 | 10:36 AM
12engine's Avatar
12engine
what about with a catback 2 1/2" exhaust with a super 40 muffler?
where did u find this data? is there some kind of calculator that can tell power (Torque and HP) increases?
Old Apr 13, 2007 | 11:09 AM
Harte3's Avatar
Harte3
Desktop Dyno 2000 program will produce some ballpark figures depending on how much hard info you feed it.
Old Apr 13, 2007 | 12:55 PM
BigBlue88's Avatar
BigBlue88
Been trolling the inline six forums for three years or so, since I got my first 300ci (88 EFI). Just search the forum and read the posts. Some people go to real dyno shops and you can find their dyno plots in their galleries. Silver Streak comes to mind.
Old Apr 14, 2007 | 12:12 AM
12engine's Avatar
12engine
thank you. when would be the best place to get the dyno software?
Old Apr 14, 2007 | 06:55 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
ebay - got the Desktop Dyno software for ~$15 to my door. The only drag is that the rpm range starts at 2,000 so you can't see the off idle numbers.
Oh, and there's not a 300 I6 option. I used an inline four, changed the boreXstroke and number of cylinders to get the right displacement.
FWIW, the "built" 300 I suimulated using the dyno software worked out like this: Comp cams 252, 4barrel, headers, etc. - torque peak was 342 @2,000, HP peak was 217 @4,000.
Old Apr 14, 2007 | 07:47 AM
TallPaul's Avatar
TallPaul
Considerably more torque and hp stock with EFI than the older carburated models. I think something like 120 hp carb version vs around 150 hp EFI.
Old Apr 15, 2007 | 09:11 PM
Harte3's Avatar
Harte3
Contact Bill from Indy at the FSP Forum. He just ran a bunch of simulations using different cams, carbs, etc. for the 300 I6. The thread is "FIGURES".
Vladimir Hyde
36
Sep 11, 2019 09:06 PM
southpole512
Jan 9, 2009 01:33 PM
Titantis
Oct 25, 2007 11:10 PM
thylton
Aug 13, 2005 09:59 PM
Tepot
Apr 2, 2004 03:30 PM
