1978 - 1996 Big Bronco
Tail Gate lock mechanism
Old Dec 1, 2001 | 12:06 PM
luxury 4x4's Avatar
luxury 4x4
When closing my tail gate somtimes one of the latches will not
lock down all the way you almost have to slam it hard for it to
latch i've oiled the chit out of it and manuely worked the latch
and it works freely but somtimes it still wont latch.
Can you adjust the strike pin any? All ideas will help
Thanks Jeff
Old Dec 1, 2001 | 12:53 PM
honney's Avatar
honney
Sure, loosen the striker w/a large torx bit and move it back just a tad (that's a technical measurement btw LOL).
Old Dec 18, 2001 | 07:28 PM
restorit's Avatar
restorit
Old Dec 20, 2001 | 12:28 PM
Redbob's Avatar
Redbob
>not
>it to
>latch
> Thanks Jeff
Jeff;
The only way to fix this is to remove the latch assy from the tailgate, oil it and free it up until everything is working easily, then re-install it. I'd recommend doing this to both at the same time, just to avoid having to take the tailgate apart twice. This is about a 1.5 hour job, maybe a little longer your first time, but well worth it.
It's surprising that Ford never got those latches right, kept using the same rust-prone pieces of 'mist' from '78 through '96. Guess it's because the Dearborn engineers never drive an old one!
Old Dec 20, 2001 | 09:33 PM
luxury 4x4's Avatar
luxury 4x4
Thanks for the info. I will try to pull it apart and do just so!!
v2addict
Jan 8, 2016 04:53 AM
z31freakify
Sep 11, 2015 12:45 PM
LeoJr
Feb 25, 2015 11:11 PM
POPAJON
Mar 1, 2011 07:51 AM
luxury 4x4
Apr 2, 2002 01:04 PM
