viair pressure switch ?????
Old Apr 14, 2007 | 04:14 AM
Green_Dually's Avatar
Green_Dually
Originally Posted by jtharvey
You've definately done the troubleshoot down to the switch. Did you get it from Seige?
yes i did,heard about them here.
Old Apr 14, 2007 | 04:21 AM
Green_Dually
Originally Posted by HeatStroked
Anyway Green, you either have a bad pressure switch, a bad relay or somehow bypassing the switch / relay and going directly to the compressor.
About 6 months after my install, my compressor would not start up, went direct 12 vdc, etc. every troubleshooting method out there. Replaced the compressor, pressure switch, etc. Ended up being a bad relay. relay seemed to meter good, still dumbfounded.
If i unplug one side of the pressure switch,the compressor shuts off.Plug the switch back in,it turns on.
So the relay is working.
Old Apr 14, 2007 | 08:14 AM
HeatStroked's Avatar
HeatStroked
Sounds like a pressure switch.
Old Apr 15, 2007 | 09:06 PM
yellow401's Avatar
yellow401
Green Dually- I can guarantee you the pressure switch is bad. I have been silent about my problems with Seige Engineering, but all I will say is that I have had NUMEROUS 200 PSI switches that were/are bad. They will keep pumping in excess of 200 psi untill the pressure relief valve opens. Siege Engineering is having some quality control issues to say the least...
Old Apr 15, 2007 | 09:08 PM
HeatStroked
If that's the case, just get the Viair pressure switch.
Old Apr 15, 2007 | 09:50 PM
jtharvey's Avatar
jtharvey
I've had a few quality control with some Seige stuff too, but their customer service has been outstanding.
Old Apr 15, 2007 | 10:25 PM
yellow401's Avatar
yellow401
I'll give them the benefit of the doubt and chalk it up to "growing pains" of the company...
Old Apr 16, 2007 | 04:56 AM
Green_Dually
Thanks thats good to know.I have to call them today,i guess ill have to buy the viair switch,i just hate to spend more money on something that they should get right.
Sarge261
Feb 22, 2017 01:30 PM
aaronlaaron
Sep 10, 2016 06:51 PM
xaviar
Jun 11, 2016 12:48 AM
ufvj217
Nov 1, 2015 11:25 PM
