Any one mounted onboard air?
Yup. Viair 150psi assembly. Made a cradle mount out of 3/16" aluminum that is bolted to the bed crossmembers. The unit is in between the frame and body. Sits up high enough to not be seen and doesn't get wet. I made a manifold with 1/4"npt electric solenoids that are controlled by a momentary rocker switch on the dash. The switch allows me to fill or dump air out of my rear airbags. I also have a triple air horn mounted up front behind the bumper. I ran a work line into the stake pocket with a quick coupling for an air hose that I carry in the tool box.
Everything was found on Amazon.com.
Well Mhatlen doesn't, his truck stays California Clean most of the time lol. I'm always amazed every time he posts pictures of how clean the underside of that truck is.
They use salt/de-icer/spray crap around me and I do a lot of winter driving hauling snowmobiles around....there's a little bit of rust that's developed on the casing of the compressor in the last year. I picked up a plastic battery box that I'm going to use to shield the compressor, we'll see how it goes.
Funny thing about my onboard air install is I'm a pipe fitter so it's all in 1/2" brass piping throughout entire truck to each wheel. Tight as a tick too doesn't loose a pound of air.
The flex is to pressure gauge on frame.
Yea no salt in California. Truck only has 55K on it so it's clean still.
LOL yea it became a challenge to me honestly. I got all the material for free, i would not paid the high cost of brass if I didn't have lots left over from work. Had to do some fancy bends on the pieces to front wheels where the frame sweeps up. But I got everything where it needed to be.
It's insulated now under cab with 1" foam rubber aluminum faced.
