Sponsored by: Real Truck
brake control for towing
Old Apr 12, 2007 | 10:57 AM
sunreiner's Avatar
sunreiner
<TABLE><TBODY><TR><TD vAlign=top width="100%">If my 03 f-350(6.0l) comes with the towing package. Is there an easy way to hook up my brake control inside the truck. Or would I have to take it to the shop. I would assume that if the wiring is already in, that there would be a simple T-intersection devise to connect to. Is that correct. Could someone help me with this one.
Thanks
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->__________________
<!-- controls -->
Old Apr 12, 2007 | 11:11 AM
johnnysF350's Avatar
johnnysF350
Your truck should have come with a short wiring harness that just plugs into a connector under the dash. The harness normally comes in the glove box when you purchase the truck new. If you didnt get one then you can purchase one from Ford. If you open the lower dash panel under the steering column, you should find the connection to the right side in the area of the lower dash support bracket. It's a 1,2,3 operation.
Old Apr 12, 2007 | 11:25 AM
PowerStrokeHD's Avatar
PowerStrokeHD
johnnys is correct about the harness coming with the truck. You can usually also purchase a harness from the controller manufacturer that has the plugs at both ends and it is just a simple plug and play operation from there.
Here is a thread with pics of the plug location under the dash.....
https://www.ford-trucks.com/forums/5...ty-wiring.html
Old Apr 12, 2007 | 04:42 PM
sunreiner's Avatar
sunreiner
My power to the brake control only comes on when I turn my lights on manually(park light or fully on). No power if I leave it on automatic lights. Is that normal? The adaptor cable has 5 cables and the brake control has 4. The only cable I do not hook up is the green one. (red-red, white-white, blue-blue, black to brown)
Old Apr 12, 2007 | 04:51 PM
Beerstalker's Avatar
Beerstalker
Sounds to me like something is wired up wrong, the brake controller should come on any time the truck is on. One of the 5 wires in the factory plug is an illumination wire that only comes on with the lights, is it possible you accidently hooked to this one?
Old Apr 12, 2007 | 04:59 PM
sunreiner's Avatar
sunreiner
Yes I did, the brown wire is for Illumination. I thought that the brown would go with the black.
Old Apr 12, 2007 | 05:08 PM
TXHillCountry's Avatar
TXHillCountry
Sunreiner, are you manually hooking up your brake controller? What I mean is that are you splicing in wires?
What brand of controller are you using?
Is there not a plug-n-play for your controller to just plug into the factory plug behind the dash?
For example the Prodigy controllers offer a Ford-specific harness with simple plugs on both ends. One end for the Prodigy controller, the other end for the Ford factory harness plug.
Like this....
Old Apr 12, 2007 | 08:44 PM
PowerStrokeHD
sunreiner, try this...
Red to Black - +12 Volts
Lt Green to Red - Stoplight
White to White - Ground
Dk Blue to Blue - Trailer Brakes
Brown - N/A
LostMayhem
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 9, 2008 12:17 AM
Roger Davis
Nov 23, 2007 03:21 PM
redandbon
3.8 & 4.2L V6
Sep 14, 2007 09:44 AM
TRICOMEDIC19
Jul 18, 2007 05:11 PM
MrNuckelhead
Jul 9, 2007 07:39 AM
