Ecu Question
Old May 14, 2007 | 02:01 PM
  #91
taisa899's Avatar
taisa899
there should be a 3 or 4 digit code right above that. So far from those #'s I can see it is out of a 91
Jim
Old May 14, 2007 | 05:35 PM
  #92
gustang818's Avatar
gustang818
I don't have an F1TF-12A650-BAB on my list. There is an F0TF-12A650-BAB which is alternately listed for "Base V8 302 5.0L FI Fed w/ AT E4OD" and as "Base V8 302 5.0L FI Standard System."
Can you tell me what the program code is? It should be 4 letters and numbers that are twice the size of the other letters and numbers on the main label. You want one that says "E1A1." The E1A1 program code is for Bronco, F- and E- series 5.0L with speed density EFI and E4OD trans.
Old May 16, 2007 | 08:35 AM
  #93
90F250351's Avatar
90F250351
i actually located the ecu i need yesterday and bought it. F1TF 12A650 TA. Thanks for all your help guys.
Old May 16, 2007 | 01:47 PM
  #94
gustang818's Avatar
gustang818
Great!!! Hope it works well for you.
Old Jul 28, 2009 | 11:01 PM
  #95
Dr.G's Avatar
Dr.G
1991 Ford HD F250 460 with E40D
I'm pretty sure I had a computer exchange from a tranny shop many years ago (I think, it was many years ago and I've owned the truck since 1992). I don't drive my truck too much anymore, I started having worse mileage than when I first got my truck (when I first got the truck I was getting 13 mpg, now less) I've had to pay for two catalytic converters (over 16 years, very expensive catalytic converters $$$$$). I just figured it was the big engine and aging on the truck. I figured maybe the 52,000 on the truck when I bought it was probably 152,000 since I had so many problems. Bad tranny, too much fuel dumping into the engine burning out the converters.
I would have bought a new truck many years (tranny going out, shop cracked my transfer case, blamed it on preexisting condition, two converters going out very expensive and frustrating) ago but raising a family and a mortgage payment didn't make it a high priority.
Recently a sharp mechanic figured out that maybe my mileage issue has been an improper ECU (or bad ECU) installed in my truck which made my truck run rich.
We started the recent investigation because now my engine light comes on every time I startup and reads code 19, electronic control assembly. The light goes off after a while.
Could a computer numbers wizard tell me what number ECU I should have in my truck?
I'm saddened that GM and Chrysler are in the situation they are in. So I have to say, if I ever buy a new truck, it is going to be from a car company that responsibly runs itself, just like I've tried to manage my finances (yes, that's Ford).
Thanks,
Wes
Old Jul 29, 2009 | 04:31 AM
  #96
subford's Avatar
subford
Dr.G
You would need to post back the Calibration Number off the drivers door post and we can come up with the part number and drawing number for the unit.
Sometimes it is not hard to get the Program Code (Catch Code) from the above numbers.
Old Jul 29, 2009 | 10:59 PM
  #97
Dr.G's Avatar
Dr.G
tag
Here it is, 9-98A-R00
thank you, Wes
Old Jul 30, 2009 | 12:47 AM
  #98
subford's Avatar
subford
9-98A-R00 =
ENGINEERING NO. or Drawing number and is the one that is printed on the unit and is used by auto resellers and part stores:
F2TF 12A650-JA
The Ford Part NO. or SERVICE NO.:
F2TZ 12A650-JA
Old Jul 30, 2009 | 09:58 AM
  #99
Dr.G's Avatar
Dr.G
Numbers
Thank you.
Wes
Old Aug 20, 2009 | 02:56 PM
  #100
Dr.G's Avatar
Dr.G
Closest I could find
7.5 Liters w/3 Spd. A.T. w/I.D. #F0TF-AJA But why does it list a three speed? I have a 4 speed when I push the button on the dash.
Old Aug 20, 2009 | 03:26 PM
  #101
Dr.G's Avatar
Dr.G
Can't figure
out what the "3 Spd. A.T. w/I.D." what does "I.D." mean?
Old Aug 20, 2009 | 03:35 PM
  #102
subford's Avatar
subford
I think it should say "3 Spd. A.T. w/O.D."
Old Sep 12, 2009 | 08:04 PM
  #103
Dr.G's Avatar
Dr.G
Oh Great Parts Guru
Can't find this, will another part number work?? Can't find an "AJA"
Old Sep 12, 2009 | 08:25 PM
  #104
subford's Avatar
subford
Do a google search with "F2TF-JA" and you should find tons of them.
Old Sep 12, 2009 | 08:41 PM
  #105
Dr.G's Avatar
Dr.G
I was looking here:
http://www.car-part.com/noninterchange.htm
Everything I find is remanufactured only
