Ecu Question
#31
The 302/E4OD combination was used in a large number of trucks over the years and worst case, a replacement computer will cost you anywhere from $25 to $150. You don't necessarily need one from a 1990. The safest bet is 1991-1993. You could use one from any year that had speed density, E4OD and 302. At some point on or after 1994, Ford started using mass air and phased out speed density. The mass air computers won't work unless you do a conversion.
#32
#35
Originally Posted by 90F250351
E8TF-12A650-F2A
EEC-IV EFI-SD20b 32K EPROM
6EC3930F01 11785 - 284 8J07
8PV
8PV
#37
So That Ecu Is No Good For A 302/e40d Combo Correct?
Here is one for you if you can find it:
<table table="" style="font-size: 80%;" bgcolor="#ffffff" border="1" cellpadding="2" cellspacing="1"><tbody><tr><td>E1A1</td> <td>5.0</td> <td>Bronco, F-x50 E-x50</td> <td>SD-Bank / E4OD</td></tr></tbody></table>
#38
The Part number you are looking for is:
NON California (FED)
Ford = F2TF-12A650-AHA or AHB
A-1 CARDONE = 785235
California
Ford = F2TF-12A650-AJA
A-1 CARDONE = 785237
These numbers are for a:
1992 FORD BRONCO 5.0L 302cdi V8 MFI (N) E4OD
Being these are for a 1992 you may have some sensor problems.
The 1991 BRONCO was the first to have the E4OD as a standard Auto Transmission so if you can find one out of a 1991 Bronco 5.0 you will be a lot better off. Sorry I do not have the numbers for the 1991.
You might try a post in a Bronco forum.
Have Fun
California
Have Fun
#39
Update
Numbers for 1991 do not use the ones above.
1991 FORD BRONCO/F150 5.0L 302cdi V8 MFI (N) E4OD
Ford = F1TF-12A650-TA
A-1 CARDONE = 785087
California
Ford = F1TF-12A650-XA
A-1 CARDONE = 785091
or
Ford = F1TF-12A650-XB
A-1 CARDONE = 785092
California
or
#41
i found one from a 1992 bronco 302/e40d that i can buy for $25.00. the part# is F2TF-12A650-AHA. will this one work?
#44
so i have to find one only out of a 1991?
The pre 1992 trucks use a small generator to output a signal and the 1992-1996 uses a switch on the rear end.
What I do not know is does the PSOM convert the off/on signal from the rear end to the same type signal the older small generator put out that went strait to the computer.
#45
