1985 460 No Start
Old Aug 28, 2007 | 01:04 PM
  #31
90F250351's Avatar
90F250351
I just checked my grounds. i have no ground from the frame to the block. the ground i have from the negative battery terminal to the front of the block is all rotted at the eye on the end of the cable where is bolts to the block. could this be why i have no spark????
Old Aug 28, 2007 | 03:07 PM
  #32
subford's Avatar
subford
NO, if it is cranking your engine is grounded well enough for spark. You do not need a ground to the frame unless you are pulling a trailer for lights or if your truck uses the frame for a ground for its taillights.
Old Aug 28, 2007 | 03:56 PM
  #33
90F250351's Avatar
90F250351
what else would cause me to have constant power to both sides of the coil? the negative tach side of the coil does not pulse when cranking. i already changed the module on the fender 3 times. what else could it be?
Old Aug 28, 2007 | 04:59 PM
  #34
90F250351's Avatar
90F250351
THE TRUCK IS FIXED!!!!!!!!!!!!!!!!!!!!!!
After all this time, the problem was the green wire on the coil. The wire was rotted and corroded and actually broke off the connector today. I cut the wire, stripped it back and attached it to the coil, and the truck started right up and runs great!
brian1080
Oct 9, 2012 05:29 PM
codys50ford
1983 - 2012 Ranger & B-Series
17
Jun 12, 2008 10:46 PM
cr506
27
Mar 6, 2008 09:00 PM
ebone
Mar 30, 2003 11:33 PM
