ATF or power steering fluid?
Old Apr 9, 2007 | 08:56 PM
brown 4x4's Avatar
brown 4x4
I'm running a Saginaw pump from a 95 E-150 on my 95 F-150. I'm currently running Type F in it as that's what my factory shop manual calls for in both trucks and vans. GM, with this same pump, calls for power steering fluid.
I'm wondering if you guys have a preference or if one seems better than the other. Mine makes slight noise when it's cold, but definately the Ford whine my old pump had.
Old Apr 9, 2007 | 09:40 PM
maples01's Avatar
maples01
I hate Ford pumps, all I've ever had whine, the Saginaw is the better one, never had one make noise, run power steering fluid in them, it's clear.
Old Apr 10, 2007 | 01:36 PM
rclarke's Avatar
rclarke
Type F is pretty much obsolete now, power steering fluid is fine but I think it is just atf without the red dye. I had a Ford engineer tell me to use Mercon 5 when I was trying to fix a noisy pump at one time. It did help.
brown 4x4
Apr 26, 2019 12:20 AM
kegger66
15
May 30, 2016 06:44 PM
Scott Yager
May 8, 2016 09:02 PM
cassell1
Feb 19, 2015 11:48 AM
BaltoMoJoe
Oct 1, 2014 05:12 AM
