Saginaw p/s pump conversion completed
Old Mar 21, 2007 | 07:11 PM
brown 4x4's Avatar
brown 4x4
I got my 95 F-150 converted to a Saginaw pump today. It's amazing how much quieter it is. My old pump was by no means a loud one, but it did have the distinctive whine to it. At idle now all I can hear is the fuel injectors clicking under the hood and a nice exhaust tone. I wish I would have done this a long time ago. I do notice it feels like it has slightly more power assist on the road, which will take a little getting used to.
I got everything off a 95 E-150 van with a 351. Pump, bracket, and pressure hose. So I can now guarantee the bracket is interchangeable with a 302. Everything bolted right into place. I had to do a little minor bending of the pressure line but it fits nicely now.
I saw a post here about possible differences in the steering box fittings, possibly needing a longer belt, and the a/c compressor bolts may be different. None were the case for me, probably because I stayed with the same year. I used all of my old bolts. I'm running Type F ATF as that's what the book calls for in both trucks and vans in 95.
Old Mar 22, 2007 | 08:13 PM
lostin90s's Avatar
lostin90s
I didn't have any problems with any 90's vans as long as same motor .But you used one off 351 and it fit yours. Glad it worked out. I have 2 E-vans lined up to get parts off of . you bet those pumps will be in my garage. They are nice for turning with larger tires .
Old Mar 22, 2007 | 08:18 PM
Talyn's Avatar
Talyn
Sounds like something i'm going to do now. My pump is ungodly loud, and it leaks.
Old Apr 11, 2007 | 12:12 PM
ErnieX's Avatar
ErnieX
Hey good info - just a question - are there certain models/engines that the Saginaw pumps came on as OEM if one wants to go the "recycled parts" route?
Thanks,
EE
Old Apr 11, 2007 | 07:05 PM
lostin90s's Avatar
lostin90s
As far as I know most had the Saginaw 88 up or so (According to local wreckers part book) . Mine and the 2 others have bee 93 -95 vans and bolted right up to 302 and the 351 also works as stated above. You need pump mount and pressure hose. In another post gut got a Saginaw pump that fit right in but needed the different hose. I'll have to read up on it.
Old Dec 23, 2015 | 08:13 PM
seelyseal's Avatar
seelyseal
where did you find your pump? ive been looking for days to get my hands on one and have come up short handed.... A little help?
Old Dec 23, 2015 | 11:12 PM
zemus420's Avatar
zemus420
damn you revived an 8 year old thread. But I'll answer your question. There were e series vans years 93, 94, and 95 maybe more not sure. They ranged from e150-350 with 5.0 or 5.8 engines that had Saginaw pumps with brackets already installed from the factory. I got mine at a pick and pull junk yard for 40$ you will need the high side p/s hose from the van everything was a direct bolt on. Took less the an hour to install and the end result was quietness. Best 40$ I ever spent.
Old Dec 23, 2015 | 11:27 PM
justcruzin125's Avatar
justcruzin125
Did they have them on the 460 van?
Old Dec 24, 2015 | 02:55 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, 460's had the Saginaw pump.
I have one on my truck.
Not sure about serpentine belt trucks, but I had to get the mounting boss off the front of the head of the donor for my V-belt setup.
Old Jul 25, 2016 | 04:57 AM
Boris Levit's Avatar
Boris Levit
is there a reason not to use the saginaw original return hose as well as the high pressure hose?
Old Jul 25, 2016 | 09:57 AM
BLDTruth's Avatar
BLDTruth
Yep, because the one on the truck is better and fits perfectly onto the saginaw pump. The high pressure hose has a different fitting on the pump, so you have to use the van high pressure hose.
Old Feb 23, 2017 | 11:46 AM
JimmiesVixey's Avatar
JimmiesVixey
now its getting revived again.
so i have a 94 f150 5.8 351w. what is the best van to get one of these?
do they not make aftermarket version? i would love a new one instead of used out of junk yard.
thanks guys
Old Feb 23, 2017 | 12:33 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You need the mounting bracket and the pulley.
THAT is why you scavenge from a van in the junkyard.
I'm sure you could bring the used pump to the parts store to swap for a remanufactured one.
You need the power steering pulley puller to get it off the bracket anyhow.
I don't know if Saginaw sells new Van pumps in the aftermarket. (I've never seen one)
Old Feb 23, 2017 | 01:17 PM
jas88's Avatar
jas88
When I got the one for my diesel Bronco, I found somebody selling the pump on eBay and asked them for a price to throw in the bracket and hose. IIRC the whole thing was about $50 shipped.
Old Apr 26, 2019 | 12:20 AM
eagle275's Avatar
eagle275
Gotta do this stock pump is crazy lol
AbandonedBronco
Jul 18, 2023 12:30 PM
cadunkle
Mar 20, 2018 12:55 PM
Krisverde
26
Jan 30, 2018 08:33 PM
moreratlessrod
Dec 14, 2016 08:31 PM
Jjona5
Nov 3, 2016 09:27 PM
