C-6 gov. difference?
Old Apr 9, 2007 | 06:15 PM
SRD4X4's Avatar
SRD4X4
Is there any difference(s) in the governor between car/truck applications?
Old Apr 9, 2007 | 06:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Have a range of years in mind? C6 used from 1966/
Old Apr 9, 2007 | 06:37 PM
SRD4X4's Avatar
SRD4X4
I should of given some more info.Tranny in truck (79) has only 1 or 2 shifts left in it.In process of re-building 1 from a Lincoln (77).I have a shorter output shaft on order and was going to use governor from Linc. so I could assemble and be ready to R&R (Truck's not a daily driver,but I want as little down time as poss.)
Old Apr 9, 2007 | 06:48 PM
NumberDummy
Are you ready for this...the book lists 20 different ones from 1973/79 trucks and econolines! The oldest number is C9AZ-7C063-A, the newest is D8UZ-7C063-B. I don't have the 1973/79 L-M parts catalog, but one of these 20 will be from the Lincoln. 1977 Lincolns came with either a 400 or 460.
1977 400 C6 Governor: D7AZ-7C063-B (Part number is from the truck parts book, the number refers to a 1977 big Ford/Merc/Lincoln (A).
1977 460 C6 Governor: D7TZ-7C063-B (this is a truck (T) part number)
D = Decade = 1970's / 7 = year = 1977 / A = Big Ford / T = Truck / Z = means nothing.
Keep in mind that while an A or T may designate a part for certain model, it may fit others as well.
Old Apr 9, 2007 | 07:06 PM
SRD4X4's Avatar
SRD4X4
They're both 460 trans. So I guess I'll try my original plan and hope for the best.Thanks
bigcrunch
May 3, 2015 12:02 PM
Gigemags05
1947 and Older Ford Trucks
Feb 5, 2015 07:42 PM
DaytonaTunnel
Mar 16, 2014 11:43 AM
73f250highboy
Nov 17, 2011 09:42 PM
havi
Modular V8 (4.6L, 5.4L)
20
Aug 27, 2009 04:56 PM
