Oil comsumption ??
Old Apr 13, 2007 | 09:00 PM
tjbeggs's Avatar
tjbeggs
the add mark only takes 2 quarts to top it off. has your dip stick tube slipped out of the bulk head fitting on the pan.
Old Apr 14, 2007 | 11:21 AM
masterc16's Avatar
masterc16
could have how do u tell if it has ?
Old Apr 14, 2007 | 01:43 PM
tjbeggs's Avatar
tjbeggs
well you should be able to crawl underneath and near the starter is the bulk head fitting. the tube is just a slide in fit, if the upper support that is bolted to the valve is loose or bents it could be an issue. if you mess with the lower end make sure the large nut on that fitting is secure so the fitting doesn't fall into the pan. thats bad! or next time you change the oil add 14 quarts and start it up. shut it off and check the level. if its not full your dip stick is not reading correctly
jstihl
88
May 7, 2017 04:06 PM
irish26
15
Aug 11, 2016 11:35 AM
caleb90
46
Jan 11, 2010 09:49 AM
wycowboy
17
Mar 30, 2004 12:09 AM
heybrent
1978 - 1996 Big Bronco
Aug 17, 2003 02:31 AM
