6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L mods??
Old 04-08-2007, 03:03 PM
farmb0y's Avatar
farmb0y
farmb0y is offline
6.4L mods??
I stopped at a dealership to take a look at the new '08 PSD's, have no interest in one since my '99 has provided for me well, but visiting with the salesman about them and he said it is illegal to modify the exhaust in any way. Just wondering if that was true and what will that do to the diesel aftermarket companies?
His reason was because the engine runs hotter and would burn up without all cooling chambers on the exhaust. My thinking is it could run cooler since you don't have all the emissions "crap" on it like the particulate filters, cat, and whatever else is included; let the thing breath and remove all the restrictions.
Any other thoughts?
Old 04-08-2007, 03:12 PM
kimminau2's Avatar
kimminau2
kimminau2 is offline
It is true that the exhaust is all a part of the emmissions system on the 6.4L. However there will be mods available for it. The engineering on these mods is already done, they are just waiting for CARB approval. Hopefully they will be able to get some approvals so that those who want to mod can do it.
Old 04-08-2007, 03:25 PM
vloney's Avatar
vloney
vloney is offline
Its been illegal to defeat or modify emissions equipment since they have been in existence, for anyone that is in the sales or repair of automotive vehicles. If you have a state inspection requirement, it may be an issue as well. The electronics on the 6.4 are so ingrained into the total system, it will create driveability issues if you remove them without doing extensive reprogramming.
Old 04-08-2007, 04:07 PM
RVrs R US's Avatar
RVrs R US
RVrs R US is offline
In a recent Fleet Ford PDF which I can't get to show here because it is a https file, it shows the section of the exhaust system that cannot be modified (roughly the front 2/3's) and the 1/3 toward the back that can be modified.
Dave
Old 04-08-2007, 09:43 PM
SpeedE55's Avatar
SpeedE55
SpeedE55 is offline
I was under the impression that even the exhaust tips could not be changed due to the fact that they dissipate the heat and keep the EGTs down. Is this true? Anyone? Anyone?
Old 04-08-2007, 10:06 PM
kimminau2's Avatar
kimminau2
I believe that is true, however as I said the exhaust mods have already been engineered as well as some programming mods. The exhaust mods are waiting for CARB approval, which as I understand will meet EPA requirements. If the mods are CARB and EPA approved they can be installed. The article I read on it had alot of input from Banks and they were pretty hopeful that they would be able to get these approvals relatively quickly now.
Also, Banks said that the DPF really does not restrict flow as much as people may think and removing that really would not make any difference.
Just what I was reading, I don't know squat all about this stuff.
Old 04-09-2007, 06:23 AM
RVrs R US's Avatar
RVrs R US
Red face
SpeedE55, My Bad! I went back and looked at the graphic on the PDF file and it is broken down into THREE sections not two:
1) For the section from the manifold to the back end of the DPF the graphic reads: "Cannot be modified; Certified components"
2) For the section from the back end of the DPF to just forward of the heat diffusers the graphic reads: "Can be modified; do not increase back pressure"
3) For the section just forward of the heat diffusers to the end of the diffusers the graphic reads: "Cooling diffuser must be utilized".
I'm loosely interpreting here but it sounds like although you have to use a cooling diffuser of some kind, it doesn't necessarily have to be OEM.
If you would like, send me your E-mail address at RVrsRUS@AOL.Com and I'll send you this Ford PDF file called "2008 Measuring Session" which has some interesting information on the specs.
Dave
Old 04-09-2007, 08:49 PM
DM-03_6.0's Avatar
DM-03_6.0
DM-03_6.0 is offline
i think a dual exhaust setup would work good for dissapating heat probably better than stock
46Whizzer
01-08-2015 12:07 PM
Brant Bowrifle
06-28-2012 01:21 AM
peterbilt379exhd
03-24-2007 05:17 PM
f150johnny
Exhaust Systems
08-01-2002 02:25 PM
teamwizard
04-03-2002 10:59 PM
Quick Reply: 6.4L mods??
