Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
carbon buildup removal
Old Apr 8, 2007 | 10:11 AM
cfrives3's Avatar
cfrives3
I have an old set of heads that I have stripped to rebuild for my Bronco. I have all the valves and associated parts out (except the valve guides). I am curious to know if there are any products or tricks I can use on them to remove all the carbon build up and crap out of the water passages. They have been soaking in the parts washer for about a week. I thought maybe Lime-away for the water passages, but I have no Ideas on the water passages. Any thoughts?
P.S. Am I posting in the correct forum? Please move to the correct one if not!
Old Apr 8, 2007 | 01:50 PM
berkad's Avatar
berkad
Why don't you take them to an automotive machine shop and ask them to hot tank them for you? Couldn't cost more than a few bucks.
Old Apr 8, 2007 | 04:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
The rust deposits (not carbon) in the water passages can be removed with dilute Muriatic acid. It has been my experience that even hot tanking won't remove those deposits.
Old Apr 8, 2007 | 05:54 PM
cfrives3's Avatar
cfrives3
Thanks for the info... One machine shop said they just used an old dishwasher. They wanted 150 bucks just to check em out. Thanks, I can handle it.
Old Apr 8, 2007 | 06:23 PM
fixnair's Avatar
fixnair
Remove the rust first using a chemical soak or circulate it for faster results. Do this before hot tanking. The caustic soda in the hot tank solution will "set" the rust and then it will have to be removed by hand.
Old Apr 8, 2007 | 06:51 PM
Ford_Six's Avatar
Ford_Six
Simple green takes carbon off in a couple minutes. I'm in the process of rebuild an engine for my Subaru, and I have never seen parts start this dirty end this clean. Seriously, that stuff is 10x better than Naptha.
Old Apr 9, 2007 | 09:17 AM
berkad's Avatar
berkad
Thanks guys for the info on hot tanking, I learn something everyday.
Old Apr 9, 2007 | 09:18 PM
GLR's Avatar
GLR
Some places use an oven to burn the grease off. I tried that once (not in the house) with an old stove. That didn't work too bad. Oven cleaner doesn't do a bad job.Another would be a drain cleaner with sodium hydroxide in it. Don't forget eye protection and good "rubber" gloves that will handle solvents.
Old Apr 10, 2007 | 06:51 AM
frederic's Avatar
frederic
An old stove in your garage is a useful too. You can use it for baking off the crud off parts like cylinder heads. You can use it to bake on powder coating if your parts fit into the stove, and you can also use it for baking on ceramic coatings onto head chambers and piston tops. I've done all three, actually.
Simple green takes carbon deposits right off, as does a brush and kerosine. Water passages can be cleaned with a long bottle brush in a cordless drill. Obviously wear goggles. Muric acid also works very well.
So does a product called "Noxon" if you find that as well. It's sold as a chrome polisher, but it likes to eat rust so it serves this purpose as well.
Anytime I clean up anything like heads or a block with any of the above methods, I generally have it hot-tanked then I blow the parts out with compressed air with a very small nozzle that I've attached to a gooseneck type of thing, so it's stiff yet flexible enough to work through some of the poorly designed intake ports, water jackets, and so on.
Working with clean parts is a pleasure.
Easy-off works great for iron or steel heads - DO NOT USE IT ON ALUMINUM HEADS they will pit rather severely very quickly.
Old Apr 10, 2007 | 07:47 AM
rsylvstr's Avatar
rsylvstr
pour boiling water in the oil/water passages, then coca cola...
