I was wandering if anyone had the bulb that illuminates the letters on the 4WD Switch go out. Mine actually burnt out and melted. But looking online I cant find a replacement bulb. It is a blue bulb that is attached to a cylinder type thing that twist into the back of the 4WD switch. I was wandering if anyone got this at a local auto parts store and what is it actually called or what I should ask for?
I'd bet it was a 194 bulb...a lot of gauges use those. I'd say just take the bulb with you to Walmart or an auto parts store and go to the lighting area and look around 'til you find one that matches.
yea its not a peanut bulb as i call it..yea i use 194 in my guages but this is a lot smaller...built onto a tube and the whole tube twist into the back of the switch.
yea i checked at the auto store they said thats a dealer only item so im off to a local junk yard to see if there is one i can take out...jus hard to find a truck like mine in those junkyards but they do have plenty of explorers with the same light
