Sponsored by: Auxito
Power steering pump squawk/squeal?! rough idling.
Old Apr 5, 2007 | 11:07 PM
thehawk789's Avatar
thehawk789
just tonight my power steering pump started giving me a rough idle and a squawk or squeal when turning. My reservoir is full, the power steering appears to be working great, but it significantly brings down engine rpm and makes strong noises from either the pulley or the pump- i couldnt tell which since they are so close together. its a 4.2 engine. and my IAC is fine.
Has anyone experienced this and what was the fix? I dont want to shot-gun a PS pump.
Old Apr 6, 2007 | 10:29 AM
KingRanchMan02's Avatar
KingRanchMan02
Take your drive belt off and check the pump pulley to see if it spins freely. Check the other pulleys too. Good luck!
Old Apr 6, 2007 | 04:29 PM
thehawk789's Avatar
thehawk789
i'm thinking one of the valves is sticking, causing it to run super high pressure all the time like when you have the wheel hard over. I'm going to try some cleaner and new fluid, might save me a pump.
Old Apr 8, 2007 | 10:19 PM
thehawk789's Avatar
thehawk789
there must have been something stuck in the valves... its fine now... i'm just gonna let er buck.
CoreLokt
Mar 14, 2016 06:13 PM
97ranger xlt
1983 - 2012 Ranger & B-Series
31
Sep 22, 2015 09:03 PM
SaturnSky11
May 29, 2014 07:32 PM
r___r
31
Feb 9, 2014 08:49 PM
frank98XLT
Mar 23, 2007 08:26 PM
