ranger falling apart
the constant maintenance is getting ridiculous..
it seems like it's falling apart...
last couple years... replaced...
both front coil springs - 1 busted
all 4 shocks ( 2 were toast..)
all 4 leaf spring hangers and shackles busted
cat
evap solenoid+purge valve .. codes
iac
pvc valve
belt tensioner- no tension
idler pulley-squawking
alternator- seized bearings
power steering lines rusted leaking
brake lines rusted leaking
timing belt busted...
water pump+t-stat housing disintegrated
center shaft bearing
and other misc. stuff i can't even remember now...
so the question is.. am i alone ? what have you replaced on your ranger
of similar vintage?
should i get out of this thing before it costs me the price of a new ranger? lol
How many miles do you have on your truck? Some of the other items on your list are mileage related. If you have between 60K and 120K miles on it, you either replace them according to your Owner's Manual or when they give out.
You live in the salt capital of the world ( I know I used to live in NE) and your truck is 13 years old. In reality it's probably worth less than 2 grand and for that price what would you expect?
The good news is that you've replaced most of the annoying things that are prone to break on this truck and with a little love you should be good to go for another 13 years!
thanks for all the responses .. keep 'em coming
take it back they will fix it. next day (they keep again overnight) pick truck up. they say reinstalled all parts and good to go. not 10minutes down the road heat goes cold...check under hood top hose blown off rad=antifreeze all over the engine!reason= kid forgot to reinstall clamp on top hose. rookie mistake in my book. they clean engine and refill rad and new top hose clamp... yes i watched him do it
so do i ever use this shop again? or if you want something done right... you know the rest....
In other words, what type and amount of preventative maintenance has the '97 received in the past 13 years?
I can appreciate you becoming tired of the seemingly continuous maintenance, but I have to agree with previous opinions that the maintenance issues that you've been and are experiencing are pretty much due or past due to be addressed for a vehicle of that age 'living' in those conditions. Assuming the truck has been in the are for the past 13 years, and considering the extreme salty conditions in your region, I'd say it's doing about what I'd expect. Depending on whether or not the truck has been receiving the preventative and general maintenance work according to the schedule outlined in a typical Chilton's or Hayne's manual, will help determine what else to expect to wear out or need attention soon. If the schedule hasn't been followed over the past 13 years, you can expect things to wear out quicker than they would have IF the maintenance schedule was followed.
Based on list you provided, I don't see anything there that would indicate abuse or abnormal wear - each of those items you're replaced were likely original and they are simply due for some much needed repair/service work. I'd say those items are pretty much all 'wear' items or have been corroding for 13 years and won't last forever; but they would likely last as long as they would in other vehicles in the area with the same type and amount of use. I'd suspect that considering the climate and such, the radiator will not last much longer either. The body mounts are probably also deteriorating too.
Just as the loose hose clamp isn't the truck's fault, neither would I expect this truck to last as long as some trucks do in much 'kinder' climates such as out west or in the southern states where their biggest concern is proper & timely fluid changes or excessive heat exposures. A quick wake-up call would be to ask yourself, "How many other '97 Rangers do I see in my town?" Chances are there aren't many and most have long since corroded away before they would have worn out.
For a vehicle that is simply considered as a daily driver and mode of transportation from point A to B, here is a simple rule-of-thumb I'd recommend:
--- If the total cost of the replacement/repair parts in one year exceeds one half the resale value of the truck, then it's time to sell it and find other set of wheels to haul you around. However, it the vehicle has sentimental value or has particular-use needs (such as you need a vehicle to haul or tow stuff regularly enough) then you may to raise the repair cost factor percent above 50%.
Typically, I have determined that if I follow the manual's maintenance routine with checking/changing the fluids & lubricants and other listed preventative maintenance, I would expect to replace typical wear items like the water pump, brake shoes/pads/rotors/drums, clutch disc and pressure plate, tierod ends, upper/lower ball joints, tires, wheel bearings, seals, U-joints, windshield glass, alternator, tensioner pulley, etc. Your costs of operation will still likely be lower than the payment schedule of a new vehicle with higher insurance as well. Realize too that the newer the vehicle, the more expensive most of the parts will be. Such additional cost factors should be considered when you are thinking of selling off your '97 and buying something newer.
JMHO,
BarnieTrk
mostly i am in agreement with your views, and in fact i do see a couple no more than a dozen of the same vintage rangers plying my local roads. i would say most are probably in worse shape than mine...
what i get out of your comments is that it really is purely a monetary calculation. i have only owned this vehicle for 3 years.. not enough time for a sentimental attachment.
right now i am underwater on the truck compared to the current market so i guess it will have to do some more work for me and i am sure it will be called upon like it has been practically daily since i have owned it. it does earn its keep moreso than other vehicles i have owned.
i guess this thread is more about venting and maybe warning than anything else but i do appreciate all the comments and insights from fellow members.
by the same token, i hope my experiences can help others.
I've replaced a number of the things you have, things like serpentine and timing belts, power steering pump, mufflers, shocks, tires, IAC and battery among other things. These are mostly time sensitive items that are part of long term maintenance and are items I expected to replace. Some may have been replaced early due to the truck sitting unused for 5 months each year. When I think about what my monthly payments would be on a new Ranger, I will keep what I have. Besides, I like it.
time will tell whether finally leak free
at least the indy shop manned up ,apologized for the inconvenience, and said it was their problem....
