Sponsored by: Kumho
Leaf Hangers
Old Apr 5, 2007 | 04:00 PM
neomac3444's Avatar
neomac3444
Leaf Hangers
Ok so i have done some reading and found its pretty common for ranger leaf spring hangers to rust out which mine have . So i have bought some new ones and plan to put them on using grade 8 bolts since they were originally held on by rivots. But i was curious if anyone knew a good torque specification to crank these bolts to or should i just crank the hell out of them?
Any help would be great.
Old Apr 5, 2007 | 08:21 PM
WarWagon's Avatar
WarWagon
Im not familiar with that hanger, but if you are talking about the bolt that goes thru the spring eye, it needs to be just snug. Use jam nuts on the bolts and just snug them up.
Old Apr 5, 2007 | 11:15 PM
neomac3444's Avatar
neomac3444
nope im talking about the hanger itself unfortuantlly.
Old Apr 6, 2007 | 06:27 AM
79superduty's Avatar
79superduty
Yea!crank them up. and you'll be fine try to use locking nuts instead of lock washers and standard nuts.
Old Apr 6, 2007 | 08:43 AM
neomac3444's Avatar
neomac3444
would it hurt if i were to use locking nuts and lock washers?
Old Apr 6, 2007 | 05:11 PM
rebocardo's Avatar
rebocardo
You did not mention bolt size. I would assume you are going to use 1/2" Grade 8. Use 90 foot pounds, BUT, watch the frame to make sure you are not bending it. If the frame starts to deflect, stop.
Then drill a small hole through the nut and bolt and cotter pin it for the safest way.
Here is what I usually do on radius arms and none have fallen off.
bolt/lockwasher/washer/material to be clamped/washer/lock washer/nut
(note all washers are grade 8 alloy)
Doing it this way, you can use an impact without holding the other side to get it tight. Then I use a torque wrench to get it within 90-100 popunds. If the bolt slips, I just throw a wrench on it while tightening the nut.
I hardly ever use lock-tite, but, if it makes you feel better, go for it
I know the spec for 1/2" Grade 8 is somewhere around 120, BUT, imo neither the frame or bracket can usually hold up to that on the Ranger/Bronco II suspension without deforming.
Old Apr 8, 2007 | 07:58 AM
cujo8's Avatar
cujo8
I had this same problem on my 77 F150's rear spring hangers. I picked up some southern replacements, but I also found that the frame had some rust around where the hangers mount. I sandblasted, Rust Encapsulated, and Painted the frame w/ Chassis Black and then I made 1/8" steel plates to put on the backside of the frame prepared in the same fashion as the frame and used them to strengthen this area of the frame. I used 1/2" Grade-8 Bolts, flat & lock washers to secure the assembly to the frame. Here's a picture of frame and hanger, you really can't see the backing plate I made in this picture.
Old May 16, 2007 | 10:07 PM
Hyperactive460's Avatar
Hyperactive460
when i did mine i used grade 8 nuts, bolts and lock washers along with some thread lock. tightened them until the lock washer was flush with the nut with out squeezeing it to tightly
Old May 17, 2007 | 12:39 PM
mudgepondexpress's Avatar
mudgepondexpress
Whatever you do, don't use nylocs! I would think 75-90 ft/lbs would be sufficient. My lowering kit came with nylocs and they stripped out at 50 lbs (grad 8 bolts). I went to the local "Fasteners" and they looked up the spec for me...1/2 nylocs were rated to 45 ft/lbs.
Kenny
scottmorgan1309
Feb 4, 2016 04:47 PM
Treacy
Dec 14, 2015 06:56 PM
powersmoked
15
Jan 26, 2012 01:17 PM
abrauer
Apr 23, 2010 06:20 AM
FordF350Baby
Dec 5, 2009 06:41 AM
