94 Ranger
Old Apr 5, 2007 | 10:35 AM
chris_c's Avatar
chris_c
94 Ranger
4wd won't engage. I took the motor off and looked at it. I didn't actually clean it, because it looked really good. I tore it apart and everything moved OK. Problem is that I am not getting any lights on the dash, and I am not getting a red light on the control module.....not even when I press the reset button.
My dad gave me the truck. He replaced the tranny about a year ago. He got the tranny from autozone or advance....not sure. There is a pig-tail that plugs into the side of the tranny on the drivers side. The one that is plugged in now is an oval shaped one. The other one is kinda square shaped. He's not sure which one was originally plugged in and do those wires HAVE ANYTHING to do with the 4wd system in the 1st place?
He replaced the switch in the dash but that didn't do anything. I didn't check the position (to make sure the motor didn't 'lose' home) to make sure it was OK.
I didn't check the voltages/resistance in the connectors that go into the control module (it's an Extended-Cab....module behind the seat) YET! I just got a DMM a few days ago.
HELP!!! LOL
Old Apr 6, 2007 | 07:43 AM
Rockledge's Avatar
Rockledge
Time to use that new DMM. Check out this thread:
https://www.ford-trucks.com/forums/5...no-lights.html
Old Apr 16, 2007 | 11:55 AM
chris_c's Avatar
chris_c
Angry
I printed out the information found here: https://www.ford-trucks.com/forums/4...ow-we-fix.html
I don't have any power going to either terminal (7 or 8) on the 8-wire pigtail harness connector. :-(
Where do I go from here? I checked the fuses, but I dodn't see any htat were blown.
From where do the wires attached to the 8-wire pigtail originate?
.........that would expalin why the red LED doesn't come on when I reste the module......LOL.
Old Apr 17, 2007 | 10:59 AM
chris_c's Avatar
chris_c
Bump...
anybody? :-)
Old Apr 17, 2007 | 09:08 PM
Rockledge's Avatar
Rockledge
Was the battery connected and when you tested terminals 7 and 8?
Also, check fuse # 7 (20A) in the engine compartment fuse box.
Old Apr 18, 2007 | 05:40 AM
chris_c's Avatar
chris_c
LOL...yeah, the battery was connected!! I haven't even done any of the resistance tests yet.
I THINK all the fuses are good, I will check them again, though.
Old Apr 19, 2007 | 05:36 AM
chris_c's Avatar
chris_c
Fuse 7 looks fine....
Old Apr 19, 2007 | 09:46 AM
Rockledge's Avatar
Rockledge
Here's an excerpt of Ford TSB 92-1-8 which describes how to test the early '90s 4WD system electrical circuits. I've also attached the relevant wiring diagrams for your '94. HTH.
Excerpt of Ford TSB 92-1-8
Old Apr 19, 2007 | 10:24 AM
chris_c's Avatar
chris_c
THANKS!! That should be very helpful.
