tranny temp guage
Old Apr 18, 2007 | 01:57 PM
fordboy_52's Avatar
fordboy_52
tranny temp guage
so i have a tranny temp guage and sincew my valve body rebuild it hasnt moved. i havnt had a chance to crawl under my truck to ground the sensor out (should peg needle). i installed this guage a year ago and i cant for the life of me remember how the guage is powered. doesnt one of the two pegs have 12v supplied to it? please refresh me
Matt
Old Apr 18, 2007 | 03:36 PM
CMOS's Avatar
CMOS
I don't have an answer for you, and I don't mean to hijack but I'm curious, is this a factory temp gauge or aftermarket? I don't have one in my Ranger.
Thanks,
CMOS
Old Apr 18, 2007 | 04:16 PM
fordboy_52's Avatar
fordboy_52
its aftermarket and i guess it still works, i grounded the guage out and it pegged. i really thought my guage would move from 140 on a 70 degree day, time will tell
Matt
Old Apr 18, 2007 | 04:23 PM
RangerPilot's Avatar
RangerPilot
How far are you driving? A short distance and it might not warm up.
Since the gauge is functional, and the wiring apparently is alright to the gauge (I assume that's how you grounded it), I'd check the wiring at the sender to make sure it's tight, then check the sender itself, perhaps the wiring was stretched or the sender damaged during the valve body work.
Old Apr 18, 2007 | 04:39 PM
fordboy_52's Avatar
fordboy_52
i have pulled a full size cab and front end from tulsa to home (around 300 miles) and the needle never moved (granted it was 60 out max)
Matt
Old Apr 18, 2007 | 04:55 PM
RangerPilot
Still...granted different vehicles, but I've got tranny temp gauges on both GMs and they warm up even on the coldest days. It can take a while to get them warmed up though, especially if driven gently and not loaded up at all. Both have shift kits though, so that might contribute.
Does the gauge bottom out at 100*? If it does, it should definetly have gotten over that long before you got home.
Old Apr 18, 2007 | 05:48 PM
fordboy_52's Avatar
fordboy_52
no, bottom is 140 and ive never seen over 200 on a 110 degree day
Matt
Old Apr 18, 2007 | 10:22 PM
RangerPilot
I'd say something was up then. I have gotten the Sierra and Silverado both up well over 200* on hot days towing a load.
I'd be suspecting an issue with the sender.
Old Apr 19, 2007 | 08:53 AM
jimdandy's Avatar
jimdandy
Location of the sender is important. It normally goes to the trans output to the cooler line. This will be your hottest point. Ideal trans temps are 170*, no more than 190*. Excess heat is what kills most auto trans. jd
Old Apr 19, 2007 | 09:22 AM
JeremyJ's Avatar
JeremyJ
tranny guages?
where is this gauge located?
Old Apr 19, 2007 | 09:59 AM
RangerPilot
It's not stock. You can get aftermarket ones from any of the major manufacturers, Autometer, SunPro, IssPro, etc. No reason for you to get one JeremyJ, they're not really helpful on manuals, the temp is much less of an issue (more durable and less heat produced since no torque converter).
Old Apr 19, 2007 | 11:48 AM
fordboy_52's Avatar
fordboy_52
i have mine installed in my pan
Matt
Old Apr 19, 2007 | 11:56 AM
RangerPilot
As are both of mine. And I can hit 200 on a hot day. It should easily be registering on the gauge after a bit of driving.
I'm still leaning towards the sender. Perhaps you can use a laser thermometer to get some temp readings.
Old Apr 19, 2007 | 12:02 PM
fordboy_52's Avatar
fordboy_52
im not going to get too excited because its been very cool out
Matt
