carrier bearing replacement
Old Apr 4, 2007 | 09:28 PM
59'er F100's Avatar
59'er F100
I was trying to follow some very old threads about swapping out carrier bearing, but was getting nowhere. So the problem I am having is I am not sure how to remove the bearing from the driveshaft. There appears to be a flange (red arrow) that appears to be connected to the splined shaft. This is the part I am not sure about removing. Has anyone any ideas on how to get the bearing off the shaft? I haver tried "pulling" the splined shaft off by hand and it is on solid. I dont want to get wrenching on it for fear of putting the shaft out of balance or causing damge to the splined shaft. Any ideas?
Thanks
59'er
Old Apr 5, 2007 | 09:08 PM
59'er F100's Avatar
59'er F100
Does anyone know how to remove a carrier bearing? I'm sure some of you have done this, right?
Old Apr 5, 2007 | 10:00 PM
jimhackney's Avatar
jimhackney
What Truck?
59er, tell us what year and model your truck is, I'll look it up in my manual(48-52)
Old Apr 6, 2007 | 12:17 AM
59'er F100's Avatar
59'er F100
I'm sorry, its a 60. I did some serious looking and it appears to be pressed on (it wont move by hand or gentle tap w/ brass hammer) I managed to get the outer "sleeve" off that the arrow is pointing to. That baby is on there!! I will try to get it pressed off tomorrow at school...they have a sweet shop there open to gearheads who know how to use the equipment!!!!
BTW, it seems I have more experience even though I am paying 15,000 for my last 3 yrs of engineering school, which specializes in reading manuals!
Old Apr 6, 2007 | 12:22 AM
59'er F100's Avatar
59'er F100
BTW, it seems I have more experience even though I am paying $18,000 for my last 3 yrs of engineering school, which specializes in reading the fine print!
Ryan
Old Apr 6, 2007 | 12:41 AM
lewislynn's Avatar
lewislynn
Thanks
59'er
Take it to a driveline shop, have them press the old one off, a new one on and have them balance it while they're at it.
Old Apr 6, 2007 | 05:17 AM
jimhackney's Avatar
jimhackney
Support Bearing Replacement
Similar part in my manual 48-52 manual shows the front collar, bearing, and rear collar inside the center sleeve inside the support have to be "pressed" off. It looks like there is a "set" screw in the rear collar and the center support holding them in place. One of these "set screws" could be a grease fitting(they don't give the name of the standard parts). I think Lewis is right, this is a job for pros.
Old Apr 6, 2007 | 05:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First off, these are not called carrier bearings. A carrier bearing is a rear axle part, and is another name for a pinion bearing. The correct name is: Drive Shaft Center Support. If I knew the exact application, I could furnish the correct part numbers. On the later trucks after 1960, the entire assembly can be purchased as one kit (4800). There are at least three types for 1961/1979 F100/350's. The later kits are DIY friendly, there's no need to have them pressed on/off. All these parts whether the entire kit or pieces from the earlier supports can be purchased from Ford or various auto parts stores.
Edit: Profile says 1960 F100. But these parts must be looked up under the driveshaft applications. There is a difference in driveshafts between 2 and 4WD, the wheelbase, and the transmission type, 3 or 4 speed or automatic.
Old Apr 6, 2007 | 08:29 AM
59'er F100's Avatar
59'er F100
jimhackney,lewislynn, Thanks for the info. This is the realization I have come to.
NumberDummy, I apologize for the terminology. I have heard these "Drive Shaft Center Support" called carrier bearings by a number of people...it sounded right to me. For particulars:
1960 F100
2WD
118" wheelbase
300-6cyl
light duty manual 3-speed
2 piece driveshaft
Old Apr 6, 2007 | 08:34 AM
NumberDummy
You have added the 300, did you change the driveshaft, or cut it to fit?
The reason I posted the D/S center support reference, is one member here went to Auto Zone and asked for a carrier bearing. After getting the info, the parts guy handed him a pinion bearing, that's not what he wanted.
Old Apr 6, 2007 | 08:39 AM
59'er F100's Avatar
59'er F100
Hey, the driveline was not changed, at least not when I put in the 300! Not sure about the previous owner! It appears that it has not been chnaged, due to the amount of grease and crud.
I understand about the terminology, as I have had a similar problems before when I first started my "mechanic'n"! Thanks for your help NumberDude!
Old Apr 6, 2007 | 08:43 AM
NumberDummy
Before tackling the numbers, I needed the info to "Show Me" what to look up.
Old Apr 6, 2007 | 09:05 AM
NumberDummy
It appears you can buy the entire assembly as a kit, like I posted about the 61/79 4800 kits above. All I have to do is match the parts from 1960 to the charts that cover ones from 1961 and later, which may take a few minutes as, there are 300 charts.
Old Apr 6, 2007 | 09:17 AM
NumberDummy
D9TZ-4800-A .. Drive Shaft Center Support Kit~Use with a bearing having an Inside Diameter of 1.37"
This kit has the same parts a 1960 F100 will use. It fits 1957/89 F100/150~use with the 1.37" I.D. bearing.
The kit has the bearing, rubber center support, both baffles, center support U shaped metal strap, flat strap, and misc pieces.
250 STROKER
Nov 27, 2014 05:12 PM
7thMcD
Nov 21, 2011 05:23 PM
lostru
Jul 15, 2011 07:05 PM
netscaner
Jun 10, 2007 06:32 PM
1954F250
Mar 25, 2006 06:38 PM
