Carrier Bearing removal from Drive Shaft.
07-14-2011, 11:55 AM
on
Ok. Its a 2006 and everything is out of the truck and out on the ground. Now how do i get this thing off the splined shaft?
Any help is appreciated.
07-14-2011, 01:25 PM
on
Take a punch and alternate sides and give it a few raps with a hammer try to hit the inner race of it.
07-14-2011, 06:06 PM
if you have issue take the shaft and the new bearing to your local machine shop or drive shaft balancer. its far cheeper then a new one.
07-14-2011, 08:32 PM
on
You wouldn't think it'd be that tight on the shaft.spray it with some aero kroil or some other good penatrating lube.
07-15-2011, 05:57 PM
on
Went ahead and had a shop press it off and the on. Joint Clutch and Gear did a great job here in Little Rock, Ar. Vibration is gone and the vibration on takeoff is also gone.
07-15-2011, 07:05 PM
on
Good to hear its fixed.gonna have to do mine soon too.
Radster
08-08-2012 08:58 AM
MrSki
08-30-2010 03:40 PM
CSIPSD
17
07-11-2010 04:22 PM
trucker41
01-21-2009 07:57 PM
2003 ,
94 ,
97 ,
bearing ,
carrier ,
center ,
drive ,
duty ,
f250 ,
f350 ,
ford ,
removal ,
shaft ,
super ,
support
