Keystone Clamps
Old Jun 9, 2007 | 02:42 PM
netscaner's Avatar
netscaner
Keystone Clamps
I am trying to remove my driveshaft.
I have it disconnected at the rear axel, but the other end (slip yoke) won't slide all the way off of the spline shaft that protrudes from the carrier bearing.
It (slip yoke) seems to have a band of some type on the end with a greese fitting on it, and I think the Haynes manual refers to it as a Keystone clamp.
Does this have to be removed first, and how do you remove it. ??
It appears to contain a rubber oil/grease seal.
Does anyone know about this ??
I just realized it's not called a keystone clamp, I guess a keystone clamp is just one of those bands that secures rubber boots like on a CV.
It's more like a rubber lined cup which acts as an oil/grease seal.
How do you remove it ??
Old Jun 9, 2007 | 03:25 PM
Towmanjbo's Avatar
Towmanjbo
most of the time you can just pull it right off the splines, but some times you just have to unscrew the keeper. By that I mean at the very end there is a "ring" with knurling on it that unscrews off the drive shaft it really is a cap holding the rubber gasket on to keep the grease in.
Old Jun 9, 2007 | 03:47 PM
netscaner's Avatar
netscaner
Thanks towmanjbo.
Knurling..............you mean rust LOL.
I'm running out with channel locks and a pipe wrench right now.
Old Jun 9, 2007 | 07:03 PM
netscaner's Avatar
netscaner
Darn, I might need two pipe wrenches, It doesn't seem to want to screw off.
Old Jun 10, 2007 | 06:32 PM
Towmanjbo's Avatar
Towmanjbo
Clean it up with some brake cleaner and reattach the other end to the diff. Make sure you are careful near the grease fitting, you don't want to break it off.
skoveng
Feb 12, 2019 02:35 AM
joegeds
Oct 20, 2016 07:49 AM
dirty1
All Things Towing
Jun 21, 2016 08:13 AM
Keystoner16
22
Oct 1, 2015 08:25 AM
DRM2004
2004 - 2008 F150
28
Feb 21, 2013 01:34 PM
