Drive shaft carrier bearing
I am trying to remove the carrier bearing on the front drive shaft of my 1954 F-250. I tried using a 3-jaw puller without any luck. There appears to be a collar on the shaft after the bearing. As far as I can see, the collar should slip off of the shaft splines.
Does anyone have any tips for how to go about removing the carrier bearing? I am thinking of applying heat next, but would appreciate any other advice.
Thanks,
Kevin
Thanks,
Kevin
71fordallen
38
10-06-2016 01:33 PM
flatbed350Stroke
20
09-04-2009 04:51 PM
59'er F100
13
04-06-2007 09:17 AM
trentmw
02-16-2006 04:38 PM
