Timing?
Old Apr 14, 2007 | 08:49 PM
Chris Gabe's Avatar
Chris Gabe
Former Vendor
Gr8ride,
You are correct about the Hot Shot's Secret. It was designed for the HUI. I am sorry it took so long to get back to you. I was having loggin difficulties. If it is an obstruction problem there is a product from www.lubricationspecialties.com I would recommend. 400 protect-o-lube. I don't know for sure if it will do the trick but if anything would that would be it. If you want to try it email me and I will break a case and just send you one quart.
Thanks,
Chris
Old Apr 19, 2007 | 06:05 PM
Gr8ride's Avatar
Gr8ride
I ran the sea foam through it and no change.
I got tired of hearing it knock, so I put a new set of injectors in it and guess what the knock is still there What do I do next?
Chris Gabe Lube, thanks for the offer but I will pass.
Old Apr 19, 2007 | 06:51 PM
crossbones2's Avatar
crossbones2
when you replaced the injectors, did you check the injector port for carbon?.........have you check the glow plugs on those cylinders?
Old Apr 19, 2007 | 08:39 PM
Gr8ride's Avatar
Gr8ride
The tips of the injectors on the passenger bank had a little carbon build up and the ports looked pretty clean. Another thing I noticed the injectors on the passenger bank were oily all the way up to the threads while the driver's side were all completely dry with just a little rust, not sure what to make of that?
I haven't checked the glow plugs, the truck starts just fine you barely have to touch the key.
Something else I should mention, on the old injectors the truck did not have a very smooth idle, but after replacing them with bosch BB code injectors it idles really smooth now.
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
Dec 3, 2003 11:33 PM
Gr8ride
Aug 29, 2003 07:54 PM
Gr8ride
Apr 20, 2003 09:30 AM
Gr8ride
All Things Towing
Mar 26, 2003 12:13 AM
